I can't (or really don't want to) believe it's the VSS again
Alright, was driving to work this morning and the speedo & odometer on my disco quit working 55MPH to "0" with no jumping. Along with that, I got (2) codes 1316 & 0300 almost simultaneously. VSS is pretty new (within the last 10,000 miles) and was a Genuine replacement part, but the speedo & the UG both say "0". I looked at the plug & it looks like it's in there, but then I was wearing a suit too.
I'm thinking electrical of some kind. I had to run to a meeting a bit ago and when I backed out of my space, the UG read 2.86MPH in reverse, but when I put it in drive I had nothing on the speedo or the UG. Drove for about 15 miles & nothing. Stopped & ran into a store, and when I pulled out of the parking lot, the UG & speedo read speed exactly the same for about 1/2 mile, and then nothing again. On the way back to the office I started with nothing & then everything started working as normal (with the exception of going to "0" on both for about 300 feet). Can't wait to see what I get when I leave today. Now if it's not the plug at the VSS, what else should I be looking for? I know when it went original one went out, I would get warnings I was driving 118MPH on the UG when I was sitting still and the speedo bounced a lot (neither being the case here).
I've been thinking on this a bit more when I recalled this thread...
https://landroverforums.com/forum/di...88/#post439323
One poster suggests that UG and the speedo get readings from different sources. If true (and I don't know if it is or not), the problem may be something else.
Looked at the GEMS obd document and found your codes listed as such....
Excess Emissions Misfire Fault P1316
Random / Multiple Misfire P0300
The VSS fault code is P0500 (which you do not have thus far)
And this from the electrical manual...
Speedometer
The Vehicle Speed Sensor (X190) sends a signal to
the speedometer in the form of voltage pulses. The
pulses are filtered by a Vehicle Speed Sensor Buffer
inside the speedometer. The voltage alternates
between battery voltage and 0 volts 6 times per
wheel revolution. The speed sensor signal is also
sent to the Cruise Control ECU (Z121), Multifunction
Unit (MFU) (Z148) (Persian Gulf States), and the
Engine Control Module (Z132).
In conclusion, it appears the sequence is VSS --> Speedo --> ECM --> OBD port (Ultragauge)
Speedometer
weird, today I drove up 33 miles to my ex-wife's place, I was measuring the mileage. I noticed about 1/2 way home after leaving my speedometer was not working. It worked going there, I got a reading when I arrived. Anyways, back to the VSS (first time no speedometer or odometer reading), took it apart, the abs plastic shaft that the magnetic wheel is on, and slips over a metal shaft, was broke off. Guess I need to get a new one for sure now. Rovah Farms has a good price it seems.
