Insatalling Control Arm Bushings
I will be doing my control arm bushings soon, and since I will be removing the cotrol arm and having a shop press the old out/new in, I want to do both arms in one shot.
If I put the front on jackstands, chock both back wheels front and back, will it be safe to remove both control arms at the same time?
A tall jack stand under both chassis side rails.
Two short jack stands under the axle.
Depending on what the shop is charging, now might be a good time to justify buying a 12 ton press.
http://www.northerntool.com/shop/too...6415_200326415
It's more, I'm sure, than what you'll be paying the shop, but you'll use it for a lot of other things too, like the trailing arm bushings which should be replaced too.
Things like: Installing hub bearings, R&R u-joints, R&R idler pulley bearing, R&R panhard rod bushings (should be done now too)....you get the idea.
Yea, i contemplated buying my own press, and really should. Seems like everything I get done is $20. The panhard bushings were already done($20), had them do the swivel bearings and bushings in the swivel *****($20), u-joints($20 a shaft). Cheated on the wheel bearings and used a drift to tap out the races and tap new ones in. I coulda just about paid for one by now. If only my nearest harbor freight wasn't an hr away.
I need this done as well . Take it to any shop?
