Kickdown Cable Adjustment?
I adjusted my 98's kick down and throttle cables according to the manual to a 1.1” (28mm) "A" dimension from the front of the cable bracket to the end of the kick down outer cable end, and then adjusted the throttle cable’s “knurled nut” to get a .040 gap from the end of the kick down outer cable to the nipple on the inner cable. This partially opened the throttle butterfly and the engine “cold idled” at 3000 RPM so I re-adjusted the throttle cable knurled **** to let the butterfly linkage just hit the stop and then adjusted the kick down cable back to get a slight gap from the outer cable end to the nipple on the inner cable which made the “A” dimension .920”, and idle was back to normal.
I don't see any way to adjust the throttle butterfly closed position other than a threaded “grub screw?”, the smooth end of which is sticking up slightly under the butterfly linkage tang, and I see no way to adjust the linkage independently of the throttle cable. I wonder if the manual's dimensions are for another year than my 98 or if my truck has a different cable bracket.
" I re-adjusted the throttle cable knurled **** to let the butterfly linkage just hit the stop and then adjusted the kick down cable back to get a slight gap from the outer cable end to the nipple on the inner cable which made the “A” dimension .920”, and idle was back to normal."
I didn't do anything further. Idle has been OK since then for some 2500 miles.
Well, 2607 to be exact. Not my daily driver but my going to the boat house ride and trailer puller when I need to move things. The other drivers get better gas mileage. I still like her, though, and aside from the more than occasional P1313 and P1314 climbing the hill from the boat house it runs fine and I can't detect any misfires myself.
Now if I could just get it to accept gas at something more than a dribble-it-in pace it would be great. The local U-Pull-It has a 97 so I'll go check to see if it still has the fuel pump assembly to get rid of the in-line pump the PO added by the fuel filter; maybe that will help the painfully slow fill
Yeah, getting it to idle down is the easy part. Like you said Phil, the throttle cable is adjusted to right at the stop. At one point the kickdown was set so that, at rest, the crimp on the cable was out 1/2" from the tube and when you let off the gas at road speed it felt like a parachute opened up behind ya.
Phil, as far as your fueling up goes, I had the same problem on my '05 Ranger. On that contraption the vapors pushed out of the tank by the rising fuel are run through the charcoal canister. I dropped that tank at least 4 times. Problem was that the charcoal in one section of the EVAP canister was a solid chunk of moldy charcoal. Cracked it open and cleaned it out.
Here is the link to my post on the Ranger forum Ford Ranger Forum - Forums for Ford Ranger enthusiasts! - View Single Post - How To: Clean Clogged Charcoal Canister
philwarner (03-30-2017)
Edit:
I found this on you tube,
