Lift and tire size suggestions
I'm getting ready to install my heavy duty OME lift on my 97 D1 and wanted to see what kinds of tire size recommendations you guys might have. I'm considering 235 85R16.
Let me know what you think.
ocdisco74 (03-01-2015)
I have a 2 inch Terrafirma lift and run that size and I'm really happy with it so far. You will probably need to do a camel cut on the rear quarter panels and adjust your steering stops to avoid rubbing. Both really easy to do.
I use Goodyear Duratracs. I got 5 tires for around $850 mount and balanced.
The first number is always the width, in mm's. So your 245 is 10mm wider than 235's.
The second number is the aspect ratio. The percentage of the width that the sidewall is tall. 235x.85= 199.75mm tall sidewall.
