lil help PLEASE. driver door handle LOCK part
Old 02-16-2014, 08:15 PM
ninehads's Avatar
8th Gear
Hi there, new to the forum and also new to LR... The Disco that I bought have the same part broken! Did you find something? I searched everywhere and only complete units
Abran, do you have the part available as you said??
Old 02-17-2014, 05:16 AM
abran's Avatar
I have the part, but I'm in Japan until the end of the month.
If you need it before then, search for Paul Grant. He parts out land rovers.
If not I can get it for you around the 28th.
Old 02-17-2014, 10:38 AM
oljohnboy's Avatar
How about this, its $199 but I would see about re keying the lock:
1996 1999 Land Rover Discovery I Ignition Switch with Power Key Door Handles | eBay
or here is just the handle, I advise you get it now due to how hard it is to find. Just have two keys and problem solved, thats what I would do or get it re keyed:
Land Rover Discovery 1 Left Front Door Handle w Key | eBay
Old 02-17-2014, 11:53 AM
glob's Avatar
Default drivers outer lock
hey bro I just joined this site today. ive had a lock issue lately and just this morn I saw for sale on ebay in the uk a lock set like you need for 25 dollars and I think free shipping for 25 dollars. best deal youll ever get. just remember when ordering from uk the drivers side is on the right side so you need to look for passenger side front left.
LAND ROVER DISCOVERY 200 300 TDI PASSENGER SIDE FRONT OUTER DOOR HANDLE | eBay
hope this helps thanks for the member!
Old 02-17-2014, 08:44 PM
ninehads's Avatar
8th Gear
Thanks gyus, but too expensive and the one at 25$ don't even come with the part that I need...
Old 10-29-2014, 11:24 PM
junebug's Avatar
HEY GUYS....SOLD THE DISCO.....
BUT WANTED TO ADD MY FIX
AND A WAY TO DISABLE THE ALARM!!!!!!!!!!!!!!!
HERE IS WHAT I DID TO FIX ISSUE:
I PULLED THE POS PLASTIC RING/LOBE DEAL THAT CRACKS......
AND MADE ONE OUT OF ALUMINUM....USED A DREMEL ,IT WAS VERY EASY!
AND TOOK ABOUT 45 MINUTES AS I TOOK MY TIME,AND KEPT MATCHING ORIG WITH METAL CHUNK...........HONESTLY,IT WAS EASY GUYS!!!!DREMEL AND A COUPLE BIT TIPS(SANDER/GRINDER/CUT OFF WHEEL)
SORRY ,NO PICS.......SAME THING JUST ALUMINUM!!!LOLOLOL
HOW TO DISARM ALARM:
I ACTUALLY FOUND THIS BY SURPRISE!!!!
WHEN THIS RING/LOBE BREAKS....YOU CAN NOT UNLOCK YER DOOR...AND IF YOU GO IN PASSENGER SIDE,THE ALARM GOES OFF!!!!!!
WELL................WHEN I WAS TAKEN HANDLE APART TO GET RING/LOBE OFF....... THE PART THAT HAS THE WIRES GOING TO IT,THAT THE LOBE HITS......... HAS A LIL TINY WHITE/CLEAR PLASTIC BALL........THIS BALL HITS ELECTRONIC SWITCH INSIDE TO ARM OR DISARM ALARM.....
WHEN I WAS SEEIN IF NEW ALUMINUM ONE WAS WORKING SMOOTHLY.....THE LIL BALL POPPED OUT!!!!!!........WELL I ALREADY HAD ALARM OFF...........SO I LEFT IT OUT FOR A BIT,TESTING IF ANY ISSUES.....NONE!!! ALARM WOULD NOT TURN ON WITH KEY IN DOOR....NO MORE HONKING!!!!!!!!!!REPLACING BALL MADE IT BACK TO NORMAL! AND ALARM WOULD TURN ON/OFF AS IT SHOULD!
SO THERE IS A WAY!!!!!!!!!!!!! TECHNICALLY..........ANYWHO I SOLD IT,AND JUST THOUGHT I WOULD SHARE WHAT I LEARNED IN MY ENDEAVOR WITH A DISCO
I WISH I HAD LEARNED THIS SOONER!!!!
PS: YA CAN'T FIND THESE STUPID PLASTIC PARTS!!!(OR IT IS DANG HARD TOO)............ MAKE THEM!!! IT WILL BE BETTER THAN FACTORY!!! AND VERY EASY!!!!
HAVE FUN DISCO DUDES!!!!
mr4x4 (09-19-2017)
Old 01-10-2018, 08:11 PM
Cliff Young's Avatar
Did we ever find a source for these plastic "clips" . My dealer was more than willing to sell me a whole new lock for $397.00,
Old 01-27-2018, 03:09 PM
partsguru's Avatar
For anyone else searching this, here is a link for a replacement part -https://www.thingiverse.com/thing:1306202 This will give you the cam and the pawl,
( STC1220 part number which I was able to verify with the online Russian parts catalog)(the pawl is the plastic "clip" thate junebug was searching for) which you can send to a 3D printer and have shipped direct to you.
I needed the cam, which I was able to send the file to a shop here in Utah and it was returned to me in 4 days for $7, freight included. Perfect fit. I requested ABS, but you can specify other materials also. The same designer has plans for headlight adjuster sockets also. Check it out - highly recommended!! Russ
XCELLER8 (01-27-2018)
Old 12-05-2020, 04:58 PM
Salmaqtari's Avatar
Default For those who might be looking for this pary. Here's where I bought it.
I found the part (Part# STC1220) at the below link.
https://www.roversnorth.com/parts/st...=yes&cartqty=1
The total cost including the shipping to my address in California was around $22. Good luck!
'BamaBoy
06-02-2010 09:38 PM
Greg
04-18-2008 04:25 AM
DetroitRover
03-08-2008 08:41 AM
TripleThreat
02-24-2008 12:06 PM
Quick Reply: lil help PLEASE. driver door handle LOCK part
