low oil pressure on startup
Old 11-18-2015, 10:48 AM
Thatguy's Avatar
Originally Posted by drowssap
i dont know if your making to much of it, most vehicle left for a few days will take a few seconds the get oil flow
I'm not talking 5-10 seconds, I timed it at 40 on Monday, that is excessive.
Old 11-18-2015, 12:09 PM
TOM R's Avatar
mine was doing that before the rebuild more so in cool months with 5w-30, all my bearings were wiped no babbet left and scored( except cam bearings were fine) no idea how I did not knock
Old 11-18-2015, 05:11 PM
binvanna's Avatar
You need to drop your oil pan and inspect the pickup. The pickup could be loose or it could be clogged. If the pickup is clean and tight, clean the oil pan and put a fresh gasket on it. If the oil pressure is still low, then it's probably time to replace the pump. Checking the pickup costs nothing but a few minutes time and a little gasket maker, and its worth cleaning it in any event.
jmason
08-31-2012 07:26 AM
eaglewing
04-16-2011 11:06 AM
tito5590805
10-04-2010 09:11 AM
DooDer
01-12-2010 10:46 PM
cgee
02-03-2008 02:24 AM
Quick Reply: low oil pressure on startup
