Maf sensor short circuit- urgent!
Maf sensor short circuit + CO volts
While testing the new maf I have just mounted, one of my crocodile clips and pins I was using to check voltages fell out and shorted on another, now the landy won't start.. any ideas.. Its 10.43 in Denmark and I have to get my kids at 14:00 so kinda need the car to be running if possible. I hope te ECU isn't fried. Any quick replies are much appreciated. With the Maf connector on or off it won't start.. I've checked al the fuses and they all seem ok unless there are some hidden ones somewhere I don't know about. Help!!!
Jason
Jason
Thanks for your quick reply. I had checked the fuses but started methodically and did it again and sure enough fuse blown.. It's running now :-) my kids will be happy...
I've just checked the CO volts and they appear to have the same volts as the battery. Any thoughts there... Factory set should be 1.8v I believe
Early LUCAS ECU info attached, has expected readings for many things.
Connector should be:
2 - red/black (ground via ECU pin 25)
3 - Blue/green (0.3 to 0.6 reference from ECU pin 35)
5 - Brown/orange (+ battery when truck on)
6 - Blue/red (MAF signal to ECU pin 22) [typical 1.3 to 1.5 volts at idle, sets code 12 if less than 0.122 volts at idle or more than 4.96 volts.]
Do you need to adjust your base idle? Assumes with a 3.9 you have an older Lucas system. The 4.0 with the GEMS system does not have a base idle adjust. One way to tell the difference is look of the MAF sensor.
P.S. I can't get codes per OBD2 in Europe this standard is first from 1999 so I need a land rover computer system to check I think if I want codes like code 12 Its a 3.9 engine. Base idle you mean tickover right? It ticks over quite fine at around 600rpm.
CO emissions don't really change whether at tick over or 2500RPM (still over 10.0 CO)
Typical MAF output voltage at idle is between 1.3 and 1.5 VDC. A diagnostic trouble code (12)
is produced if MAF voltage is:
• less than 122 mV with RPM in excess of crank speed.
• greater than 4.96 V with RPM less than 976 for more than 160 milliseconds.
Does this mean that if the crank sensor is not working it would give a problem also?
How can I test that?
