Manual Clutch Pedal for the r380 - heavy and squeaky fix?
Noticed that my clutch pedal is a bit on the heavy side now, and occasionally it squeaks and clicks when I press and depress it.
I found a similar issue and solution on a blog by Defender 90 XS on his D90 whereby he used a little lubrication (they used some 3-in-1 oil) to lubricate the push rod attachment for their clutch pedal.
Does anyone have any tips on reaching the Discovery one? I looked at the engine bay, and could not see easy access to it, and under the dash it seems a bit of a challenge.
Thank you.
Thank you.
buttocks
12-31-2014 12:53 AM
koldstart
10-19-2014 01:44 AM
Blakesrover
02-20-2013 10:31 PM
