Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery I
Register Forgot Password?
Old 01-13-2012, 08:36 PM
Member
joking41
Default need some advice on a buy, 1995 disco 1
im looking at a 1995 disco 1, just some questions if i should be concerned about.
truck has 120,000 miles, starts up nice no real engine noise till warmed up, then there's a tick on the passenger side when its revved over 2000 it stops. i cant see anything else wrong with the engine or transmission, low works awesome spun the back tires when i romped on it. interior is in good shape dash kinda crackly. srs is flashing in the middle of the tach. new tires ect no leaks ect ect.
he's asking $1800 ima go up with $1600 the car books at $1612 kbb.com.
just want some input with you guys about the buy it seems solid! has power everything works great i fell in love with it. comments advice anything please my freinds
__________________
2000 land rover discovery 2/ 125k
1975 honda gl1000 cafe racer /69k
Old 01-13-2012, 08:55 PM
Jake1996D1's Avatar
Senior Member
a little tick here and there isnt bad just depends on what you mean by tick...
How did the oil look on the dipstick? I'm willing to bet the oil wasnt changed regularly early on. Search on here and other forums about ways to get rid of tick using Marvel Mystery Oil and other additives (only real hope with out tearing it down)
I'd check for signs of HG going bad along with checking the rest of the fluids tranny included.
If I am buying a truck that I plan on keeping I'd ask to borrow it for a day and do a deep inspection including pulling the spark plugs and valve covers and seeing how the engine is running and if there is much in the way of sludge.
Just my 2c
__________________
96 Disco - 35's, lockers, 3-link etc.
95 Disco Tray Back project - 265/75/16's chopped and bobbed
Northeast Land Rover Club
www.nelrc.com
Lucky8
Old 01-13-2012, 09:11 PM
Senior Member
Ticks can be a number of things. Sticky lifter (MMO might handle that) is one. Oil pump cracked is one, see photo. It will make enough PSI to turn off light, but not the 40 PSI you need at 2500 rpm. Unscrew oil switch and screw in pressure gauge to test. Slipped cylinder liner is another, usually comes from overheating the engine. No easy repair usually, may involve a process of machining the block for a "top hat" liner, or pinning the liner, or other practices.
You could easily be looking at $1700 in repairs or more. So why not arrange for an indy mechanic to look it over. An hour of his time could save you thousands.
__________________
Last edited by Savannah Buzz; 01-14-2012 at 09:48 AM. Reason: should have mentioned engine repair methods
Old 01-13-2012, 09:45 PM
Member
joking41
the oil was a little dirty i removed the oil cap and theres a little buildup on the top of the valve little specs other then that it was bright n shiny inside. doesnt smoke other then that tick from the back left valve cover i say that because i tried the screwdriver to ear trick and it sounded up top more then down low tried both.
how much do the oil pumps crack on our vehicles? still has alot of power other then that tick the truck is solid i test drove a good 30 minutes 0-65 mph and nothing no shakes vibrations ect ect. ive worked on alot of cars and it sounds like a lifter is stuck and or the oil when warm loses some duribility like thickness and or like from syrup to liquid no the oil is not syrup it feels like 10w40/30 when cold.
__________________
Old 01-13-2012, 09:48 PM
Member
joking41
ow and the tranny fluid looked great before and after the test drive not that dirty had a good red color to it and smelt good i do a pretty good check on my vehicles before i buy them. but good tips guys keep them coming please!
__________________
Old 01-14-2012, 12:03 AM
Senior Member
tencreds10
If you buy a rover: personally I would go with the 1994-1995. They have less electronics to have go wrong. About the tick: I would test the oil psi cold at idle and at 2500rpm. Then when it is warm (needle is straight across, 9:00 position) at idle and at 2500rpm. See what the numbers are. I personally have spent countless hundreds of dollars trying to figure out what my ticks and rattles are in my engine and I can't figure it out. I am now in the mind set of "when she completely quits on me, then I will just replace it all" Rovers are a lot of fun. I would offer less for starters. Cash goes along way and if you can save $200-$400 by just offering less, why not? lol You can always add more! I would get a head gasket test kit from napa. It costs almost $50.00 but you can use it for ever. This would be helpful to knowing if the head gasket is bad or not. Also, take cap off radiator and look for crap in it. (BE CAREFUL, THE PLASTIC IS OLD AND BRITTTTTTTLE) Turn the engine on and open the oil cap, just let the engine idle and see how much smoke comes out the cap. If it a lot then that means the valves are bad. You should have some smoke but not a lot.
I own a 1995 Discovery 1, so if you have any questions on potential problems, pm me!
__________________
Discovery I 1995 with 178,XXX
New oil pump, timing chain, fan clutch and radiator... NO LEAKS! Knock on wood...
Old 01-14-2012, 12:09 AM
Member
joking41
Awsome! I did run it with the oil cap off and not to much air was passing threw to be honest. Hg rarely go bad on the older disco 1's my friend had a disco 1 and still running strong at 297k when I last talked to him a month ago. I can't see this vehivle having minor to no problems and I'm anal about checking cars also thank u guys!
Old 01-14-2012, 12:30 AM
ihscouts's Avatar
Senior Member
Quote:
Originally Posted by Savannah Buzz View Post
Slipped cylinder liner is another, usually comes from overheating the engine. No repair usually.
Not true, a top-hat can be fitted.
__________________
97 SD Altai Silver
The three-position Lucas switch--DIM, FLICKER and OFF.
The other three switch settings--SMOKE, SMOLDER and IGNITE.
Old 01-14-2012, 01:09 AM
Member
joking41
I'm trying to stay up to par with all ur guys abreviations and such I really can't say the land rover is nothing short of a awsome truc
Old 01-14-2012, 08:24 AM
leadfoot's Avatar
Senior Member
Go for it. From what I read you are mechanically inclined and the LR will keep you entertained. It's an awesome car and as such will demand some attention.
__________________
Land Rover Discovery 1997 152K
Mitsubishi Montero 1998 140K
Toyota FJ Cruiser 2007 50K
BMW Z3
Tags
125, 1995, 95, code, discovery, engine, gl1000, idle, job, kbv, land, ntruck, rover, ticks, turning, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
