If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
l was working under the hood i notice a small pooling of antfezs by my water pump. Now i know where the leak is i just don’t know what’s it’s called where it’s at it the it’s pooling on looks to be a gasket what kind of gasket it is and how hard to replace it. i with i could take picher to show you.
Sorry for my spelling long night.
not much help as to go off any thing would henlp.
__________________
1998 land rover disco1 mil 10000
If it is a gasket above the water pump and under the intake manifold that is the valley pan gasket. Intake has to come off. See attached from your RAVE, under "engine"
If is is the gasket between the water pump and the block then the fan and WP have to come off to get to that.
Need Parts? paulgrant@mac.com, or 203-770-1699 willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
Took it to a indy shop today to diagnose why it wont start unless I jump it first and it well start fine for about three days or so this is what they came back with,
Diagnose drivability problems/client concerns and advise.
RESULTS:
- PRessurized cooling system and did not see any coolant leaking in the valley.
There was a little bit on top of the water pump, but is not leaking at this time.
- Upper rad hose is Very bloated and is leaking at the rad. Advise replacing hoses.
Fan clutch is very loose. Should replace.
- Vehicle does not have any fuel pressure after test driving. Checked and found that
the fuel pump relay is working and is supplying good output to the fuel pump.
**Advise starting with the fuel pump and fuel filter for the hard start condition.
- Cannot check alternator because the vehicle wont start. Battery passed load test /
alternator looks new.
SRS light
fault code 65280
The ignition supplied voltage is or has been too low. Cleared code and it stayed off.
Dose this look right?
I’m just not sure what is really going on with it.
__________________
Why could they not test the alternator? They took it for a test drive, but say they couldn't test it because vehicle won't start? How did they test drive it without starting it?
Originally Posted by tornado_735I keep motivating myself saying that some poor bastard had to do the very same thing during the Camel Trophy and that I'm no different from him.
