If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
Do I need to change to a lower weight oil for wintertime? Right now I have Rotella 15w 40 in it. I don't want to have problems when the outdoor temps get below zero.
__________________
98' Discovery LE - 84k miles
New alternator, heavy duty fan clutch, battery, spark plugs, rear brake rotors, brake pads, fuel pump, muffler
My first car
Need Parts? paulgrant@mac.com, or 203-770-1699 willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
It can get below zero on some days. Average is about 10-15 degrees.
__________________
My first car
RAVE says 15w 40 is good to about -10 degrees celsius. Thats about 14 degrees fehrenheit. It might be pushing it....
__________________
My first car
Switch to the 5w-40 for the winter, thats what I do and our temps are about the same as yours, very cold at night but in the upper 20's to low 30's during the day.
