Oil spray with oil pressure gauge sandwich adapter
Did some wrenching last night to knock some things off my to do list. One of them was to install a Glow Shift Oil Pressure Sensor. When I started my truck after the install was finished, oil sprayed everywhere! I obviously cut the engine right away, so no damage there. Everything looked to be installed correctly. Ports were plugged, gaskets turned to the right side. The only thing I can think is that I need to use a specific oil filter with the sandwich adapter. I just used a regular purolator that was on sale, but I have seen folks mentioning using a MANN 950/4. Any idease on what the issue may have been? Currently the sandwich adapter is removed and the oil filter is back in place with no leaks or issues.
jpluncford21 (01-28-2017)
Where did you decide to mount your gauge?
I'll go ahead and tell you that the GS mount is MASSIVE and, to me, looks pretty ugly. I'm looking at modifying my a pillar and fabbing a lower profile mount up with fiberglass or Bondo. There are some good tutorials from folks on here. Maybe check it out
logan_gibson (01-31-2017)
If it is god awful Ill check with my dad to fab up something. He deals with carbon/fiberglass every day.
meltdowndave
02-01-2010 04:20 PM
Landys4ever
08-10-2009 01:06 PM
