p0300 random misfire and p0451
#71
Today i found the connector for the fuel tank pressure sensor. It shared a connection with the taillights. I verified that that was the connection with a multimeter using continuity with the sensor's connector located under the rug in the cargo area.
Unfortunately however the connector was intact and perfectly fine. I think it may be time to consider replacing the sensor.
#72
#73
#74
#75
#76
#77
As far as price my local junkyard is pretty fair so.
#78
Same here, I can snag a complete used Rover 4L engine for $675 with 70k and the 4 speed off the same low mileage truck is $375, t-case is $275. I looked up a brand new AEL pump assembly on BPUtah and they want $300 whereas a non-AEL assembly on Rovahfarm is $109. The only difference is the pressure sensor with two more wires and the type of fuel line connectors...... BPUtah has a AEL "kit" which consists of the pump, two flex hoses and sock filter for $195? All this is mind boggling. Tom bypassed his pressure sensor because in his case it effected the throttle position sensor and he was dumping fuel and the motor ran like dog poop. They're wired in the same circuit back to the ECM. Yours is fairly specific but I worry that it will eventually lead to the TPS faulting.
mr4x4 (04-26-2015)
#79
... Tom bypassed his pressure sensor because in his case it effected the throttle position sensor and he was dumping fuel and the motor ran like dog poop. They're wired in the same circuit back to the ECM. Yours is fairly specific but I worry that it will eventually lead to the TPS faulting.
BTW, it seems ironic that the AEL system has what is called an "anti-trickle valve" designed to keep you from overfilling the gas tank by trickling fuel in, but if my 98 is typical the only way to fill the tank at all is to trickle fuel in verry verry slowly because otherwise the neck fills up and shuts off the gas pump even if the tank is nearly empty.
#80
Mine shifts around 53mph, these are hydraulic transmissions, they shift by pressure not throttle position.
If you tackle the fuel filler vent line then you'll fill the tank normally. The weather is getting better...... it would drive me nuts living with that problem. If it was -30F I still would take care of it because I cannot stand disorder........ I live on a lake in the woods and I was the only idiot to clean up three years worth of leaves laying on the woods floor within our property lines of course. The neighbors think I'm loosing it. We happen to be having a very dry spring....... all it would take is one small spark.
