p1179
Check the sock on your current pump, if it's clean then go on up to the inline filter. If you know the inline is good then swap the pump and check pressure.
Why would you think it's the FPR? It's doing it's job of letting fuel go back to the tank at idle with 32 psi.
As far as the MAF reading how do you know it's low? How do you even know what information your getting is the sensor? It's information is being passed through the ECU to the Data Port, not directly from the sensor and I have no idea what the environmental conditions where on the day you took the reading.
It tells me the FPR is working as advertised.
I'll say it again, check the sock filter, inline, if those are good then replace the pump. Retest. Go from there if need be. When they run like crap at idle or just off idle it's usually fuel pressure related. The FPR's are damn near bullet proof, the only time I've heard of them being replaced was by folks who where throwing parts at a problem they didn't understand. If you have the bucks go ahead and throw em, if not use the pump you have already bought to find out if indeed it is the FPR not seating.
The 28psi reading is way south of 34.8 needed to feed the beast.
changed the pump with the one I had, new sock, no change in pressure base readings, if I block the return it will now build 90-100 psi fast
changed out the fuel filter with a new one no change in readings
when I took off the filter the fuel coming out of the engine side line was nasty looking though, I would say maybe that line has crap in it but I think pressures at almost 100 psi would blow out a clog?
again unplugged vacume hookups 1 at a time and plugged did not help
not sure why I am not getting pressure, when I block the return and psi goes up she runs great unblock line pressure drops and wants to die
plugs at the pump looked fine no fried or corroded, the plug on the drivers rear frame looks fine too, added dielectric grease since I had it open
there is probly something stupid simple I am overlooking
Any idea if the injectors are original? If it where me I would change those out like your planning and see what happens after that. Don't change out the FPR with a new one until your absolutely sure that's it. Keep chasing the nickel and dime stuff, you never know. I wonder how the fuel feed line looks inside? The rails are also prone to rust from the inside out and you'll see evidence of that inside the injector screens once you do the swap.
