Plastic Sh!t Broke.
#22
do this, hi lift jack across floor behind front seats, start adding offroad gear in the cargo area to weigh it down i bet i carry 50 + lbs back there all the time,check my thread
get a front d2 drive shaft with the transfer case flange this might fix part of the shake
you definitly need a mounted front winch for the static weight, i am sure i missed it how many inches of lift? iirc the tf hd needs alot of static weight, more then my ome
you still running sway bars?if so they can be part of your problem
should not be to hard to locate a used steel gas tank skid that like 50 pounds alone probly
paul grant has i believe a set of front and rear bumpers 4 sale and maybe sliders? but think he is in vt, shipping would kill you from vt to miss.
#23
Would I need a GBR or Tom Woods drive shaft or is the d2 with the correct output flanges and piecese suffice for getting the job done. And I have a TF HD lift that's supposed to be 2" but because of the lack of weight I think it is more. And I tried to replicate the sound and make a video on my iphone but it's not able to pick it up without the noise from the exhaust leak. Im thinking of going to SAE to ride and also to get some personal opinions on what I should do and also on the weird sound I keep hearing.
bcolins
06-02-2011 07:40 PM
