Pulls to the right under braking. And death wobble!
My D1 pulls to the right under braking, it's not horrible but it's bad enough where I have to correct it.
Sticky caliper? Wheel bearing?
It also has death wobble over large bumps in the road, I have read it could be a whole host of things. Swivel pin preload, panhard rod bushings, tie rod ends etc. Has any fixed theirs and can tell me what they did and how to check which part is bad?
Any help is appreciated!
(to take the front bumper off, is it just the 4 bolts on the frame horns?)
I will agree with the caliper starting to stick, at least thats where I would start looking first for your brake problem. As far as your death wobble I would jack one side of the front end up and really man handle the tire around (side to side up and down) and see if you can see or feel any movement and then do the same on the other side.
Yes its just 4 bolts that hold the bumper on plus you headlight washer hose.
I still have not resolved my issue,unfortunately I cant have the truck disabled until thanksgiving so I have learned how to live with it until then and hope it makes it, I had similar issues but I found it wasn't pulling under braking but it was self steering in the ruts at intersections, the ruts are where I brake so that's what I thought at first, but upon a few weeks of carefully watching when it happens I noticed it only happened at stop lights with heavy tire ruts. I attribute the loose steering, self steering, and death wobble to a combination of swivel pin pre-load being too light and worn bushings due to a PS leak, at least that's what makes sense to me. I have found that if I slightly turn the wheel a bit and hit bumps at an angle it doesn't go into a full death wobble (I am guessing that while driving straight there is a weak spot on the damper and while slightly turning the damper absorbs it, but who knows), cant miss them all but I know where most of the bumps are on my daily drive so it helps, well that and absolute minimal driving until it is fixed!
just my 2 cents!
just my 2 cents!
Quick update. I'm going to go out on a limb and say the death wobble is caused by my ROTTED steering stabilizer:
0_IMAG0195.jpg?t=1288734289
Also, should I Be looking at left or right caliper?
Thanks.
