Radiator shopping. Got a good source?
Look at it this way....the Disco radiator displaces heat from water and oil.....that's two coolers in one! If you buy them separately, they would cost the same (or more) in combination. In retrospect, it would probably cheaper if they were separate.
Anyway, a recore is the best thing to do with these full metal radiators. Less overall waste to the environment. It will work and perform just like or better than new. The new plastic/aluminum ones.....that's a different story. Once the plastic caps start to go, which are not replaceable, you need to buy a whole NEW radiator!
If I ever needed a NEW solid radiator for the Disco....I'd give Griffin another call....
