If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
When I unlock the doors on my '99 DI, the front door locks go up and you can open the doors normally. However, both of the rear door locks go up partially, but the door won't open with the outside lever. You have to reach in and pull it up, and then it will open.
Is that an actuator problem, or a central lock issue?
Thanks,
Pete
__________________
1951 Willys M38
1973 Porsche 911 RSR
1974 Bronco Ranger
1984 Jeep CJ7
1994 Defender 90 POE
1999 Discovery I SD
2004 Audi S4
2007 Jeep Commander
I know, I know...I have a problem...nothing from the '60s
Actually you might be able to adjust your actuator. When I fixed my window problem in the past (rollers were broken) I removed the little black actuator by unscrewing two screws. When I had reinstalled everything I had that exact same problem. I had screwed the black box too far downward and all I had to do was unscrew the two screws shift it up or down as needed and it was fixed.
Thanks guys! I'll try the fixes first and move on to replacement if necessary. Caleb, if I can get a couple more things fixed on this thing, you might see it roll past Tupelo on it's way to Starkville for 2nd semester.
Pete
If you roll into Tupelo give me a holler! I'll PM you my number! And I might be going to Starkville my freshman year of college so we might be seeing more of each other!
I had an issue with my door locks where the driver's door locked when I accidentally leaned on the latch, all the doors automatically locked and the driver's door would not unlock no matter what I did. Pulling up with pliers would not work, reaching out the window and trying to unlock with key would not work, nothing.
The next day I sprayed all the linkages with PB50 spray lub and no more issues with the locks. Try it, if that fails, call Paul Grant.
__________________ HAPPY TRAILS TO YOU FROM. Danny Lee 97 Disco Driving MEANANDEROVER
