rear end failure
rear end failure
Hey everybody. It's been a long time since i've posted; hope everyone is doing good.
I was pulling my tractor out of the field the other day and suddenly the front wheels started spinning but not the back (i was in CDL low). I dropped the tractor and switched to 4H and heard some ugly noise from the rear. Went back to CDL and limped it to the house then put it back in 4H and put it in gear and let out the clutch. The rover just sat there in gear and made some ugly noises so I had a friend look underneath and the rear propshaft was turning so I either broke an axle or something in the final drive.
I haven't opened up the cover yet to look at the rear diff but i've been calling around to find out what my options are. There are two 97 Discos in a junkyard near me. They only want $250 for a complete rear axle assembly. I called a place that rebuilds diffs and they were talking more like $1500.
Does anyone have any advice on junkyard axle assemblies and whether or not a rear axle assembly from a 97 will fit on my 96?
Thanks all; any advice will be appreciated.
Cover?
Just replace the diff assembly if it's bad. You should be able to get a junk yard diff for $100. The axles are full float, so you should be able to pull the shaft out and look at it. If you had steel wheels you can even do it without removing the wheel. No need to replace the entire axle. Also, $1500 is crazy money for a rebuilt diff. You could get a locker, new gears, and setup for less than that.
Call or email Marty Powell. I just got a 3rd for my 98 for $75 shipped. I'm putting it in so it can be driven while I re-do the ARB that's in there. Make sure you tell him whether you have a rotoflex or u-joint so he gets the right one so you don't have to mess changing it.
overlandrovers@yahoo.com
270 576 7922
270 576 7922
The following 2 users liked this post by jhmover:
discoguy96 (08-31-2015),
jafir (08-31-2015)
270 576 7922
270 576 7922
I'd probably buy an ashcroft part instead of Detroit, they have more gears 6 instead of 3 or something like that, so that should help get a little more friction for the limited slip to transfer power to the wheel with traction. I'm not speaking from experience though, but maybe someday I will be
Ashcroft Transmissions
I recommend calling Erik at lucky 8 directly, sometimes their website is a little out of date, and he can sometime do prices even better over the phone: Lucky8 Llc. - Take the road less traveled...
