rear main seal on discovery leaking
Old 09-01-2014, 12:51 AM
pawright's Avatar
Default rear main seal on discovery leaking
what else should i do when i take out the engine?
Old 09-01-2014, 07:57 AM
TOM R's Avatar
Just drop the trans, do not remove the rear bearing cap just pull the seal and clean the area, oil and install new one
I say drop trans cause it is probly leaking all over including the pump seal
Old 09-01-2014, 08:37 AM
pawright's Avatar
while it is out it appears that the welsh plugs have not been replaced so i will be replacing them and to make sure we have the leaks covered we will be replacing the sump gasket and front seal as well any other ideas?
Old 09-01-2014, 11:50 AM
ihscouts's Avatar
3.9 or 4.0 and how many miles on it?
Old 09-01-2014, 12:44 PM
TOM R's Avatar
what are the welsh seals? if they are the crucifix seals in the rear main cap leave them alone, I was warned against it when I did mine apparently disturbing that bearing will cause premature failure, I just did the rear main big ring seal and leak fixed might as well drop the oil pan and check the pickup then reseal the gasketless pan
Old 09-01-2014, 04:19 PM
pawright's Avatar
3.9 litre v8 duel fuel 94 model 215,000 kms (135,000 miles) on clock but its hard to tell if it has been changed at any time. engine number indicates range rover but from what i have been able to find out they used the same motor in both.
has been a city car so lots of cold starts sitting in traffic but low kms
low compression (90) should be abut 150
welsh plugs are like caps put in the water jacket they usually rust and fail so will replace with brass ones
Old 09-01-2014, 05:09 PM
TOM R's Avatar
AHH FREEZE PLUGS, or more correct block casting plugs, whats your location? Canada? uk? and whats a dual fuel v8?
Old 09-01-2014, 06:11 PM
ihscouts's Avatar
LP/Petrol.
Old 09-01-2014, 06:19 PM
pawright's Avatar
location is australia
duel fuel is petrol and gas
Old 09-01-2014, 06:31 PM
TOM R's Avatar
petrol? you mean propane? thought petrol was gasoline or is that just what you call it in oz?
Quick Reply: rear main seal on discovery leaking
