So what did you do to your Disco today?
  #3881
Old 08-14-2016, 07:51 PM
WaltNYC's Avatar
I removed the maf, and IACV, cleaned the throttle body and IACV and the female side on the plenum, reinstalled and after a long highway drive I had no idling problem.
  #3882
Old 08-15-2016, 10:56 AM
fishEH's Avatar
Are those the Irok ND's? If so what size and how do you like them?
Originally Posted by Doug18
Fixed the O2 sensors so now ...
  #3883
Old 08-15-2016, 11:49 AM
Kilby's Avatar
Well, technically it was yesterday but I got new front cover & oil pan gaskets installed, plus a new Airtex water pump. Test drove today. Seems like she's running ok. At least now there's no coolant pouring out of the front of the motor.
mr4x4 (08-16-2016)
  #3884
Old 08-17-2016, 02:53 PM
WaltNYC's Avatar
Cleaned the IACV and rebuilt the passenger side seat switch for about the tenth time. Carbon builds up on the contacts.
  #3885
Old 08-22-2016, 07:46 AM
WaltNYC's Avatar
Change oil/filter & air filter. Swapped out failed cruise control ECU for one from a 4.0 GEMS DII. CC now operational and I'm loving it.
  #3886
Old 08-23-2016, 12:08 AM
MrValingo's Avatar
Valley gaskets, valve cover gaskets, water pump, adjusted kick down cable, and an oil change. Coolant flush in progress
  #3887
Old 08-24-2016, 11:21 AM
hrhoward's Avatar
R&R front drive shaft universals.
Not to terrible bad of a job.
  #3888
Old 08-27-2016, 11:23 PM
jimvw57's Avatar
After 5 years of ownership, My son rode in the rear jump seat and steadied his prized possession, a 65 inch flat screen TV as it was being moved to his new living quarters.
first time anyone has used the jump seats and it worked flawlessly. He asked if it was legal to use them and I told him to put on his seat belt... He is 26 years old...
  #3889
Old 08-28-2016, 12:06 AM
Clay99d2's Avatar
Default Crank position sensor and Freaking lug nuts
Changed the cps and planned on changing brake pads... Lug nut covers are a PITA. Had to use angle grinder to cut through and used flat head screwdrivers remove the stainless steel caps. Got 3 wheels finished and one cap of the 4th and gave up for today.
Tomorrow... I get to change and bleed brakes on the D2... then change the steering and tie rods on the D1.
Clay
  #3890
Old 08-28-2016, 01:05 AM
MrValingo's Avatar
Got some exhaust adapters and reattached my muffler to the y pipe. It's so quiet now.
Quick Reply: So what did you do to your Disco today?
