So what did you do to your Disco today?
#3541
#3543
I put my sunroof motor back in. So far so good. Cleaned up the motor guts and got it all back together. It works, it's loud, but it works. Need to tear apart the the rest of the sunroof to finish lubing everything up. Hopefully can finish leak proofing everything else in the process. I can post some pic on my build thread if anyone gives a .... about messing with one of these motors.
#3544
#3545
FINALLY found this post again!! My original $7 bulbs are still going strong. I wanted to order a set for my other D1 and needed to find the post to know which ones to buy.
These have been great and I highly recommend them. Very white bright light.
http://smile.amazon.com/Rover-Discov...9003+discovery
Bulbs are shyt! One just went out on me... Bastards!
On another note, I installed my Realistic TRC-482 CB today.
Mounted the antenna up top in front if the forward sunroof. Drilled, grommetted, sealed and even siliconed the sunroof motor screws and access where it usually leaks from. All cb wires hidden and secured. Looks clean. Made the mount brackets out of some aluminum strap I had lying around and gave it the brushed look. Cb works great.
#3547
95 96 97 98 99 00 01 02 Land Rover Discovery Series II/SD/SE/SE7/LE/LSE/XD 2pc 12v 55w H4/9003 Xenon Gas Super White High/low Beam Light Bulbs 5000k (1pair) - Ropes - Amazon.com
Blue tinted, made in some asian factory with no QC.... I'm sure they're great. lol.
I use these, and recommend them over any other halogen H4. And I've probably tried close to all of them.
<b>Osram Rallye 70/65w +50 H4 bulb</b> 64205
#3548
*barf*
Osram Rallye 70/65w +50 H4 bulb 64205
Haters gonna hate.
#3549
They don't throw blue light. The light is extremely white and bright, as I said above. I've bought every grade of the Sylvania lamps, none have been as white or bright and many have lasted much less time. These have outperformed the $35-40 Silverstar Ultras at a fraction of the cost.
Haters gonna hate.
Haters gonna hate.
#3550
Anything with a sylvania label (NOT osram) is cheap, made in china junk. the blue filter just removes colors of a certain wavelength; it does make the light "whiter" but it also lowers intensity. Try out the osrams one day, you'll be surprised. I still would like to put an upgraded headlight harness on the Disco, I'm sure theres a huge voltage drop on the stock one.
