So what did you do to your Disco today?
Old 02-04-2017, 04:34 PM
El Duce's Avatar
Been going on lots road trips and desert exploring recently so this week I gave it some new terrafirma shocks, and air filter. The junkyard near me got a new rover aswell, so I grabbed an oil filter to radiator oil hose that leaks less and an jump seat. Stoked!
  #3972
Old 02-04-2017, 08:28 PM
saintdel's Avatar
In the past few weeks I replaced the rear sway bar mount bushings which were missing completely, also the link bushings. Last week I changed the fuel pump as a prophylactic measure since this truck has 178000 miles on it, 174000 of which i know not the history. It was easy, the hardest part was getting the compression ferrules off the old tubes and on the new. Will be replacing other common fail items as I go along.
  #3973
Old 02-08-2017, 03:10 PM
hrhoward's Avatar
Default After replacing IACV....
Reset Adaptive Values. Idle is dandy again. Did it with my laptop.
  #3974
Old 02-11-2017, 03:18 AM
Thatguy63's Avatar
Default Blew out my Transmission on my way to costco.
So the very day my tax return graces my account my Transmission goes **** you *******!! so shopping for a new one. Ebay has a lot of good priced used transmissions
  #3975
Old 02-11-2017, 08:21 PM
LeakyDisco's Avatar
On the flip side, at least your Rover was kind enough to wait until you received your return.
  #3976
Old 02-11-2017, 10:40 PM
stillruns's Avatar
70 degree temps today, why not go for a ride:
  #3977
Old 02-12-2017, 06:18 AM
loanrangie's Avatar
Almost finished my rear storage unit with fridge slide, 50ltr Waeco just fits with my modified handles.
Still need to make a couple of drawers and add carpeted plywood to the top.
  #3978
Old 02-12-2017, 05:25 PM
Thatguy63's Avatar
You know what thats true i got a guy on ebay whos got a almost new one for 400 so yeah two weeks to driving again.
  #3979
Old 02-14-2017, 08:57 AM
Tacitus's Avatar
6th Gear
I finally decided to re-bolt my big 'off-road' jack back to the stowage box attached to my roof rack. I had taken it off to jack up my surplus military HMMWV a while back but that project is finished now.
  #3980
Old 02-25-2017, 12:50 AM
rickroverover's Avatar
Default Saved a few bucks...
These pics will tell it all. I am to tight to spend the $70 each for new rear regulators so here is my $4.54 fix for both.
Had to shave a wee bit off with a grinding tool and drill to get into the channel after opening the end up but was minimal .
$4.54 total
the only dimension i remember is the 2 big ones are 1 inch
note the thickness difference
cut the 2 that are too small internal diameter to fit.
they will bend to get over the cap.
last, super glue the thick one that has the larger hole to the base ..
and you are done.
Shiftonthefly1 (03-08-2017)
Quick Reply: So what did you do to your Disco today?
