Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery I
Register Forgot Password?
Old 01-14-2012, 01:46 PM
Member
Default Spark Arc Sound, rough idel, sometimes stalls
94 Disco... hear a wierd tack tack tack sound sort of like a spark or electricac arc ... sounds like it is near the coil... but I can see any sparks or arcs. Engine all of a sudden is a little rough with noticable less power on acceleration. Sometimes it will stall like it is either fuel starved or air starved.
Air filter was dirty... replaced it. Put in new fuel filter too. Same issues and that sound is still there. Not constant no set rythm to it, but there every 3-4 seconds.
New coil time? Is there a test for the coil?
Joe
Old 01-14-2012, 01:52 PM
Senior Member
That tack tack sound is the arc, and if you do this in a real dark place you can see the sparks. Might be lucky and just a bad boot or wires.
__________________
Old 01-14-2012, 02:08 PM
Sam95disco's Avatar
Senior Member
Quote:
Joe
Got A Code 45 HO2S Right Bank see page 3
__________________
1995 Discovery V8i
142K
new water pump, fan clutch, thermostat, lower radiator hose, powersteering hoses(3), alternator and driveshaft rubber coupling.
1990 Toyota 4 Runner SR5 230k(fell on its side, left her my friend said it was still on when we took off, I was drunk. Came back, all fluids gone. Topped her off and she started right up.)
Old 01-14-2012, 05:43 PM
Philip Lawrence
Send a message via Skype™ to Spike555
You have a short, start the engine in the dark and open the hood and look for spark.
__________________
www.marshill.org
Walk by faith not sight.
The "Storm Trooper", 1997 Discovery with 212,000 miles.
www.20liters.org
Old 01-16-2012, 10:17 PM
Member
Thanks for the responses... traveling this week with limited time to reply...
Looked at night... saw small little sparks every now right on top of the coil between one of the coill terminals and the boot of the ignition wire that leads to the distrib.
Ordered a new coil... found a Bosch on sale for $60... New wires, and while I'm at it a new distrib cap and rotor. Hope that will fix it all. Plugs were new last year but may pull them while at it and hope to see some milk chocolate.
Will let you know.
Joe
Tags
1995, acceleration, arc, arcing, boot, land, landrover, plug, rover, sound, stall, wires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
