If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
We have a 97' Disco I, 229K miles, runs great, most of the time. However, when it is cold and particularly when it has rained or has been very humid upon startup it will chug and clug and ping and pop when you give it any gas and wont get over 1K RPM. If I let it sit for 15 min and it warms up, it smooths out and runs perfectly. Once I ran it though a Car wash and it did this after it was running smooth, but only for about 5 min then it went back to running perfect. so It's got to have something to do with water getting somewhere. No codes no lights NO CLUE. any ideas?
I also have ABS light on (ever since I bought it) and no Cruise control.
We love this vehicle and would love to figure this out. I think we can get at least another 70K out of this thing!
You can get as many miles as you want with enough maintenance. The ECU getting wet and causing strange behavior is a common occurrence. It's solved by opening it up, drying out, and sealing it shut with silicone. It could also be water getting in the ignition system. Check both ends of plug wires and coil pack connector. Dielectric grease can be used to waterproof any connectors.
What he said.
Passenger fender, infront of the washer bottle.
Unhook battery, remove ECU, open it, dry it, seal it with silicone.
Done.
As for the cruise, vacuum leak, start at the brake pedal and replace any cracked/broken line.
This is so common on DI's that there are guys who waterproof these things for a living.
Send them your ECU, they waterproof it to MIL SPEC's and send it back to you.
Originally Posted by tornado_735I keep motivating myself saying that some poor bastard had to do the very same thing during the Camel Trophy and that I'm no different from him.
