Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery I
Register Forgot Password?
Old 01-23-2012, 04:44 PM
Junior Member
Default Sun Roof Woes
Good afternoon folks.
I removed the headliner to troubleshoot my leaking sunroof problems. Once it was out, I was able to see that there is a hair line of air between the gasket and the sun roof itself. I'm assuming this is why my Disco is fogging up on cold nights.
Neither sun roof motor works, I searched here, and found out I could use an allen wrench to open and close the roof. That was a great tip. I've noticed two problems, though. First, the part that slides into the handle-looking thing at the front was jammed below. I used a flat-head screwdriver to make it go back in the slot properly, but the window still isn't quite sealed. Do I have to replace the gasket? I would, ideally, like to have a working sun roof, but if it comes to it, I'll seal it shut completely.
Thanks in advance, I really appreciate having this forum to turn to when things go sour.
-Steven
Old 01-23-2012, 09:53 PM
Philip Lawrence
Send a message via Skype™ to Spike555
Marine grade sealant on the outside of the sunroof and the leak should stop.
__________________
www.marshill.org
Walk by faith not sight.
The "Storm Trooper", 1997 Discovery with 212,000 miles.
www.20liters.org
Old 01-24-2012, 01:12 PM
slanginsanjuan's Avatar
Senior Member
Quote:
you mean where the plastic frame touches the metal roof? like a bead under the trim all around? i'm about to do mine and wonder if the seal between the glass and the frame is working.
there's a lot of stuff here on the leaking sunroof. I'm thinking I might need to replace all seals in order to get close to leak proof. the water ingress bulletin is frightening.
__________________
SLANG
96D1 105K
02D2 60K
Old 01-24-2012, 01:15 PM
Danny Lee 97 Disco's Avatar
Senior Member
My headliner has been out and is staying out. My sunroofs seal fine. The only leakage i had was at the corners of the metal frame where they used buttjoints and applied sealant. The factory sealant leaked. A bead of clear 50 year silicone did the trick.
I guess if the seals are deformed or cracked from UV damage whatever, they may require replacement.
__________________
HAPPY TRAILS TO YOU FROM.
Danny Lee 97 Disco
Driving MEANANDEROVER
Might be a REDNECK in a Rover
Just Don't Flip Your Rover Over
See my Rover Pics: http://community.webshots.com/user/DannyLee97Disco
http://www.youtube.com/watch?v=dZz2qlKeAJk
http://www.youtube.com/watch?v=MYyxc...eature=related
THESE ARE FOR THOSE WHO I OFFENDED
Tags
2012, problems, range, rover, sunroof
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
