Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery I
Register Forgot Password?
Old 01-23-2012, 01:26 PM
Junior Member
Default Tach erratic / Alternator appears ok
Hello-
I know an erratic Tach may mean a bad Alternator but I've had the issue for 2 months and my battery is ok although I NEED to test the alternator myself.
So turning on headlights, honking horn, turn signals will cause the Tach to move up and down, and it never reads more than about 1000 RPM even when on the highway.
It tends to be jerky and perfectly timed with electrical current changes when turning things on and off. It's a '95 Disco I, v8. (i need to fix up my signature I know!)
Old 01-23-2012, 01:53 PM
Senior Member
The tach wire on the back of the alternator is a "flying lead" that pushes on to a metal tab. It does not bolt down (at least on my 97). It sends pulses there, and my frequency meter said about 270 hertz at idle. If alternator is doing the job, battery volts will be between 13.6 and 14.4 at idle, nothing else running. Will drop a little as amp drain increases, but should stay above 13.2 with everything on. Schematic attached, part of the RAVE package.
__________________
Old 01-23-2012, 04:12 PM
Sam95disco's Avatar
Senior Member
Mine did that right before the alt went out, Its doing it again. I used my multimeter and batt is fine, disconected the batt with truck running and everything worked. I think mine does it cause of the code 44 I just got.
__________________
1995 Discovery V8i
142K
new water pump, fan clutch, thermostat, lower radiator hose, powersteering hoses(3), alternator and driveshaft rubber coupling.
1990 Toyota 4 Runner SR5 230k(fell on its side, left her my friend said it was still on when we took off, I was drunk. Came back, all fluids gone. Topped her off and she started right up.)
Old 01-23-2012, 04:58 PM
Danny Lee 97 Disco's Avatar
Senior Member
From what I have been told by others who own a Discovery, you should NEVER DISCONNECT THE BATTERY WITH THE ENGINE RUNNING!.
I know this was a common practice years ago, if the alternator was bad, the engine would merely die. With todays sensitive electronics, you can create havoc. Bad idea.
My tach bit the dust quite a while back, it works when it wants to.
__________________
HAPPY TRAILS TO YOU FROM.
Danny Lee 97 Disco
Driving MEANANDEROVER
Might be a REDNECK in a Rover
Just Don't Flip Your Rover Over
See my Rover Pics: http://community.webshots.com/user/DannyLee97Disco
http://www.youtube.com/watch?v=dZz2qlKeAJk
http://www.youtube.com/watch?v=MYyxc...eature=related
THESE ARE FOR THOSE WHO I OFFENDED
Old 01-23-2012, 08:25 PM
Senior Member
If tachometer is indeed all that is dead, and battery is charging corectly -
Does vehicle have an OBDII port to plug in a scanner, I'm not sure when/if Gulf vehicles got that. If it does, you have a $69 fix from Ultra Gauge, that will give you lots of gauge displays, plus code reader scanner.
Old 01-24-2012, 12:43 PM
Senior Member
My tach continues to get more eratic, behaves like a bad solder joint. Does not want to work in the cold, gets erratic and suddenly sprigs to life, drops suddenly if I let off the gas, jumps a little, then runs fine for however long it decides to. It works as little as I do>>>>
__________________
Danny Lee 97 Disco
Old 01-24-2012, 01:19 PM
Junior Member
Default Thanks - Just downloaded Rave last night
Quote:
Thanks for the help on this to you and everyone else. I will check out the schematic that you've attached. I also just got the Rave manual last night. The reason why I think the Tach is ok is that I've been running light this for 2 months and figured it would have caused the battery to die already. I am going to have a look at it tomorrow in the day light and If I find a resolution I'll post it. Will definitely do the alternator tests too.
__________________
1995 Discovery I, v8 3.9L
151,000 KM on Odo (I suspect it's much higher)
New fuel pump, hood pull, offroad lights, custom roof rack.
Old 01-24-2012, 01:20 PM
Junior Member
Default ODBII port
I don't believe it does as it's a '95, but I'll check when I get some daylight to take a peek.
__________________
Old 01-24-2012, 03:32 PM
Senior Member
We have had people with a short in the wiring harness make tach drop, but that's hard to track down a skint place.
__________________
Old 01-24-2012, 08:27 PM
Senior Member
Who knows, a skint wire could cause havoc. Getting to the back of the tach to put in a replacement is a bit of a pain.
__________________
Danny Lee 97 Disco
Tags
alternator, battery, classic, dying, erratic, erraticly, jump, land, range, rover, tach, tachometer, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
