Tire Size
#22
#23
Yeah I only had 3" RTE springs in there with some spring wedges under the back spring perches. Your truck looks good. You may want to toss some rubber isolators between your front spacers and the upper spring perch to reduce any harshness/chatter.
USNAVYORDNANCE (01-27-2015)
#24
#29
Search the Camel Cut. You trim a very little bit off the back or the front and rear fenders to clear the tires. You can make it look good where you wouldn't be able to tell by glancing at the truck.
With 3" of lift you should have no problems with 235/85 or even 255/85 with very little trimming.
jigray3
10-14-2010 06:54 PM
jigray3
10-09-2010 09:27 AM
