trouble with charging system
Old 02-08-2011, 05:57 PM
nahtanoj's Avatar
Default trouble with charging system
ok, i'm lost. bought my 96 and was told it needed a new alternator. tested it on the vehicle, was not charging.
replaced it. well, it still isn't charging with the new one on.
continuity to from (+) on alternator to (+) on battery is good. same with (-).
i can't find anything on the other 2 wires as to what they should be connected to, (+) or (-).
anybody got any ideas? or a copy of the electrical troubleshooting guide?
thanks
jon
Old 02-08-2011, 06:11 PM
Go to the "tech section" on the DI page and find the link on proper belt routing.
If the belt is routed wrong the alternator will not put out enough charge and your water pump will turn to slow.
Old 02-08-2011, 06:16 PM
nahtanoj's Avatar
actually what i just popped on to check, thanks.
Old 02-08-2011, 06:22 PM
nahtanoj's Avatar
and, it's wrong. should be an easy fix, we'll see if that helps.
Old 02-08-2011, 08:13 PM
Hopefully thats all thats wrong, unfortunately you probably wasted money on a alternator.
Old 02-08-2011, 09:45 PM
nahtanoj's Avatar
quite possibly, but at least i know there is a good one in it. charging the battery over night and i'll test tomorrow.
Old 02-09-2011, 06:57 PM
nahtanoj's Avatar
belt is on properly. battery charged. started it up and what do you know, my tach works!!!
and i tested to alternator, putting out 14.7 volts.
a new thing to add to buying a new rover, CHECK THE BELT ROUTING!!!
thanks again,
jon
Old 02-09-2011, 08:02 PM
You're welcome Jon.
Matt_Attack352
01-13-2014 09:55 AM
Marsalad
11-21-2012 10:11 AM
steve
02-18-2009 12:02 AM
maddash6
01-13-2008 08:12 AM
RTLimo
08-15-2005 12:42 AM
Quick Reply: trouble with charging system
