Vacuum System Layout
I Checked the Manual and the RAVE...
I am looking for a diagram or a schematic that details the vacuum system layout. My vacuum system is a complete mess.... Charcoal canister is not connected, no cruise control, etc. It may be the source of some of my nagging little issues...
I want to get all new vacuum lines and do it right.
On your engine the vac lines run from the left side of the plenum to the fuel pressure regulator and the other leads to the vac. advance module on your distributor. On the right side of the plenum the hard plastic line runs to the charcoal canister.
That's all. Used to be that the vac. line diagram was on the underside of the hood at the leading edge.
Thanks for the heads up. Regardless, I want everything to be the way it should. I have a T coming out of the FW on the drivers side and its not connected to anything. There is a vacuum port on the throttle linkage that is not connected. Charcoal canister is not connected...
I will look for the diagram, but most of those images under the bonnet are pretty well washed out after 15 years.
who likes pictures?
Since you searched and have rave and actually tried to find the answer I am more than happy to help you sir.
Diagram....
the other diagram...
This is the vacuum pump for the cruise control system. (It is completely seperate from the engine vacuum system) My finger is touching the primary vac. line which leads back to the T. Normaly this pump resides under the circular punched out hole in the metal framing under the Jack / Power steering res. / air horn. I just pulled it our to show you...
The CC vac. line T... the 90* section leads to the CC diaphram on the throttle linkage and the 180 * section leads throught the Firewall / bulkhead to the brake line vacuum switch.
The T leads to this diaphram controlling throttle for CC...
This is the fuel pressure regulator line... I was incorrect earlier when I described the routing of this vac line to you... I was working from memory... The FPR vac line terminates at the nipple on the plenum under the IAC bypass hose on the backside of the plenum.
Keep in mind this is my '95 Disco so you have no vac line running from the top of the plenum to the distributor (which you don't have. )
Diagram....
As said, no vac lines and the engine will run poorly... Also, as said, there are multiple and seperate vacuum systems. The T pictured above is for cruise control. The entire cruise control vac system is 100% independent of the engine or evap system. Missing or broken or inoperative cruise control vac lines will not affect engine running at all.
