Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery I
Register Forgot Password?
Old 12-26-2011, 12:25 PM
Member
Default Water pump Gasket Sealer Question
Hi Guys,
Going to be removing a bad water and installing a new pump today -
The question:
Do I need to use a gasket sealer along with the gasket that came with the new pump?
Always appreciate any and all input..
Trav...
__________________
1994 Land Rover - Discovery - V8i - 95k
Newbie to the Land Rover world
Son of God
By the Blood of Jesus Christ...`
Old 12-26-2011, 09:00 PM
Senior Member
I used a very light application with mine. See atached page from RAVE, in typical Roverspeak, it is called a "joint washer", see #5 on drawing.
__________________
Old 12-26-2011, 09:05 PM
Danny Lee 97 Disco's Avatar
Senior Member
Isn't that a gasket? So did you just apply sealant with no gasket?
__________________
HAPPY TRAILS TO YOU FROM.
Danny Lee 97 Disco
Driving MEANANDEROVER
Might be a REDNECK in a Rover
Just Don't Flip Your Rover Over
See my Rover Pics: http://community.webshots.com/user/DannyLee97Disco
http://www.youtube.com/watch?v=dZz2qlKeAJk
http://www.youtube.com/watch?v=MYyxc...eature=related
THESE ARE FOR THOSE WHO I OFFENDED
Old 12-26-2011, 09:41 PM
Member
Quote:
That is why I am asking - I read the RAVE before - the same section - It doesn't mention anything about using a sealer.. and the gasket I have is paper - oil wouldn't work - in my mind at least..
Trav...
__________________
Son of God
Old 12-27-2011, 09:08 AM
Senior Member
Thin RTV or Hylomar (spray if you can find it). You are holding the gasket in position on a vertical surface for assembly, and it is paper thin (oil just holds it). Can also be done with Oklahoma grade full strength RTV if no gasket around, but gasket is the best way.
__________________
Old 12-27-2011, 11:03 AM
wheelgarage's Avatar
Senior Member
I always use a thin layer of ATV, black or grey...
In regards to Hylomar, I recall when that stuff came out. Not too sure if the formulation has changed, but I never had success using it when I rebuilt a few rotary engines, always had issues with curing. The new ATV's and the good'ole Permatex sealant will always do the job....
__________________
1996 Discovery SE7 - 5-Speed
Fully protected by Redline Oil / Lucas Grease
Terrafirma: MED Duty Lift Kit, Steering Damper, Castor Correct Radius Arms, Rear Cranked Radius Arms, Shock Turret Rings, HD Track Rods, Extended Stainless Brake Lines
Tyler-Engineering Steering Damper brackets; Polybush Orange Kit; OEM Swaybar Bushings; Adventure Roof Rack; Hella 500's; ARB Front Bumper
265/75/16 Cooper Discoverer STT; Terrafirma 16 x 7 TF100 Alloy Wheels - Anthracite
Work in progress......
Old 12-28-2011, 05:56 PM
Senior Member
I would use the gasket only, no sealer.
Old 12-29-2011, 12:10 AM
Jake1996D1's Avatar
Senior Member
Quote:
Same! I didnt use any on my last one IIRC just a little bit of grease to get the gasket tacky enough to stay in place while mounting the new pump. They also sell those single shot t-stat and water pumper sealant packets at most auto parts stores if you go that route.
__________________
96 Disco - 35's, lockers, 3-link etc.
95 Disco Tray Back project - 265/75/16's chopped and bobbed
Northeast Land Rover Club
www.nelrc.com
Lucky8
Old 12-29-2011, 03:39 PM
Chris-bob's Avatar
Senior Member
I used RTV applied thinly with an acid brush when I did my water pump a few months back. Just enough to cover the gasket on both sides.
__________________
1996 Discovery SE7 stock V8 with 5 speed manual. 85K original miles.
Link to download the RAVE http://www.landroverresource.com/rave.zip
The smaller workshop manual is here.
http://www.landroverresource.com/doc...hop_Manual.pdf
Originally Posted by tornado_735 I keep motivating myself saying that some poor bastard had to do the very same thing during the Camel Trophy and that I'm no different from him.
ECU pics -
http://smg.photobucket.com/albums/v6.../Land%20Rover/
Tags
blue613, discovery, gasket, hylomar, info, land, pump, rover, sealant, sealent, sealer, stuff, tois, versachemsuper, water, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
