Weird *pop* sound
Weird *pop* sound
I've seen people talk about it in other threads but I haven't found an answer. Wheel bearings good, swivel ball bearings good... I replaced everything on the drivers side just to check to see if it made any difference.
When the wheels are facing forward, with the trucks weight on them... turning either way results in a loud clunk that can be felt in the floorboards. It doesn't do it if the wheel is turned a bit past center, but anywhere around center it will do it.
I got up under the truck and had my girlfriend rock the steering wheel back and forth. I can hear the clunk from the entire axle, it doesn't sound like its coming from one specific place. Also, nothing visible is moving at all. I replaced all the tie rod ends.
I can't see any movement of the steering box, I checked and the bolts are tight.
Any idea's before I go secure an entirely new front axle? Normally I have no problem fixing issues, but this one is driving me insane!
