Weird sound after new parts
Old 04-16-2015, 05:59 PM
swak6287's Avatar
Default Weird sound after new parts
OK, after I replace the rear pads (worn to the metal), new rotoflex, new ujoint, new gearbox mount (last one was not even there anymore, this weird sound appeared It goes faster as I step on the gas. I am wondering if it is the rear rotor that is binding with the pads? Yes, I greased the Ujoint. I am dumb-founded.
Here is the link.
Old 04-16-2015, 08:18 PM
TOM R's Avatar
Dude that's horrible, you do the front by joints yet?, getting trans in place now has the front drive shaft squeaking?
If front drive shaft let's loose kiss transmission goodbye, big hole
IMO do front u joints
Old 04-16-2015, 09:51 PM
swak6287's Avatar
I replaced the rear ujoint. But I did drive it with the front shaft, no rear shaft, to move the rover, and no squeeks.
Old 04-17-2015, 08:06 AM
fishEH's Avatar
You need to do some in person trouble shooting.
Is it engine related? Belt or pulley? Does it happen when revving the engine in Park?
Is it drivetrain related? Does the squeak coincide with tire rotation or is it faster than that?
Make sure the rotors aren't rubbing on the dust shields.
Did you grease the new U-joint?
Old 04-17-2015, 08:19 AM
drowssap's Avatar
remove the shaft and take it around the block see if it makes noise.
sounds like tin check the backing plates.
also sounds wheel related, your drive shaft would be spinning fast than that,
jmho
Old 04-17-2015, 08:21 AM
TOM R's Avatar
That sound is in drive line for sure and speed/rotation related does not sound to me like dragging brake pads
How slow can you drive and have the noise?
If its at walking speed I would walk while someone drives to try and pin point a wheel or if sounds from under truck
I still say front drive shaft, bone dry u joints at the transfer case end
Old 04-17-2015, 08:47 AM
swak6287's Avatar
I am going to pull the shaft tonite and replace the ujoint. MIght be installer mistake when doing the install. I do remember now that a few pins did fall into the cap while being pressed. Then, those pins were put back to where they were suppose to go. Ihope that why it is squeeking.
Old 04-17-2015, 04:02 PM
TOM R's Avatar
So at this point what u joints have been replaced
Old 04-17-2015, 05:29 PM
OverRover's Avatar
I'm going with U-joint, but on the odd chance check the rear rotor mudshields. Might have bent 1 into the rotor when you replaced the wheel. Had it happen on a RRC and it made a similar squeak sound.
gbob
10-13-2014 09:54 PM
Jeremiahbullrog
04-21-2012 06:17 AM
Ederd
Freelander
09-04-2011 11:08 AM
DiscoveryHouston
05-03-2011 01:39 PM
bmwrovers
10-19-2006 01:02 PM
Quick Reply: Weird sound after new parts
