wireing questions
wireing questions
OK I removed the abs pump for more room, I am gonna put a remote fuse box there, and the relays for my off road lights
Question is the round plug with 2 large wires that was connected to the pump runs off the 40amp fuse by battery right? If I can get power from that plug will save me some wiring and help keep clean under hood
Ideas since I put the big abs fuse in and have no power at that plug
I do not believe you are correct. The abs pump receives power when the ABS ECU initializes the relay, not constant power. I read up on this and the slabs/ABS ECU monitors the sensors and sends power to the abs pump when the right situation arises. The plug I think you are talking about is C0507 and the wires are brown/red(powered by pump relay) and black(ground).
I like the Blue Sea busbars, or similar
https://www.bluesea.com/products/272...18_Stud_5_Gang
Install it over near where the ABS stuff was, run a single #2 from your battery terminal to it, then feed your terminal/relay block from that. You can also earth through it, running an earth cable down to your chassis like the one from the battery on the other side.
Then you'll have a good source for future additions.
If you're using an Odyssey or DH Platinum that has top and side posts you can run the supply from the side post to make it neater.
Retrofit heated seats LR3
Hi all
I have found the following on disco3.co.uk.
http://disco3.co.uk/forum/topic90406.html?highlight=Retrofit+heated+seats&st art=15
essentially you need 4 wire connector into the hvac and 2 wires to left and right side footwell as well as connect 2 earths together.
Going to try soon, I have already replaced the original seats with electric leather heated seats.
avking
02-18-2009 05:10 PM
