'03 disco "mode" button not working
Old 01-25-2013, 02:11 PM
jna97's Avatar
Default '03 disco "mode" button not working
have an '03 disco and the mode button has never worked. when i push it, it has never lit up and nothing on the instrument cluster. i checked all the fuses and they look to be ok. anyone have any ideas? could this simply be a bad switch?
Old 01-25-2013, 02:23 PM
Pik's Avatar
Pik
Pik is offline
Maybe the bulb is not in the dash, or has burned out.
Does it illuminate when you put the ignition key in?
Old 01-25-2013, 03:37 PM
Racer X's Avatar
The one on the steering wheel controls, or the one on the shift console?
Old 01-25-2013, 04:03 PM
The sport mode on the console is fused by the tran computer. You can however check the wiring input/output at pins 45 & 25 on the tranny ECU connector - attached.
edit - that would be 51 and 25.
File Type: pdf
Old 02-04-2013, 09:15 AM
jna97's Avatar
i checked all the fuses again and they are good, maybe it's just the bulb (instrument cluster). my mode button is at the shifter base.
Old 02-04-2013, 10:37 AM
You might use an OHM meter and verify if you have power, in and out of the switch also.
angasreid
12-16-2023 07:45 AM
cmossman
07-19-2010 03:06 PM
yarddawg
12-10-2007 05:19 PM
Willie 00D2
10-25-2007 09:06 PM
Quick Reply: '03 disco "mode" button not working
