1/8" oil over FULL line on dipstick
Uhh what? Maybe if you filled the oil so high it was sucked in to the PCV port it would affect your PCV system. Otherwise as Tom pointed out there is a vacuum on the top end and a tendency for a positive pressure to be built up in the bottom end (caused by blowby) but this is alleviated by the PCV system connecting the bottom end to the top end. The reason you do not want to overfill your crank case is that the harmonic balancers on the crankshaft will aerate the engine oil like a smoothie and remove much of the lubricating and thermal properties of the fluid.
The only way and engine will start leaking is from the PCV system becoming clogged. The crankcase builds pressure, and if it can not be relieved (pcv clogged), it will push oil out of the seals.
The PCV commonly carbons up on most engines and causes leaks, not too much oil. My Caddy even had a new intake system because the holes weren't big enough from inception. Later models are fixed.
PS, when you start a post that states the engine gets it's vacuum from the crankcase, no one is going to trust a word you say.
PSS, your cruise control unit has a separate vacuum pump under your air box. It is in no way tied into the engine vaccum...
We already established that being 1/8" isn't going to hurt anything.
A LOT of people on here are pretty **** retentive about their stuff, so if you decide to drain some oil out, just take off the oil filter and pour it out and you should be good. May need to do it twice. There really isn't another reasonable way to do it. When I was younger and dumber I tried to take out an extra quart by taking out the drain plug and putting it back in real quickly. Didn't exactly work out if you know what I mean...
rsr50
12-26-2012 04:17 PM
