1173 Code Check engine Light. Please Help
Hello All,
I have the 1173 code triggering the CEL light about twice a week now. Does anyone have experience fixing this? Is it a bad passenger side O2? Just curious as I would like to fix this. All four 02's were replaced by me at 73,000 miles, now at 100,000. I thought they should be good for at least 60k-100k
Any help would be appreciated.
Touche. Hey rovin, what's the procedure for replacing and inject.or. Helping this guy, figured the injector was leaking. The thread is labelled 5 codes.........can you chip in your experience with replacing an injector in that thread. Thank you in advance. To boss, sorry for the partial thread hijack.
Not worries,
When I change my oil tomorrow. I will crawl under there and listen for a exhaust leak.
My scanguageII does not show me any signals on the O2's What type of scanner should I get or rent to help diagnose this. Maybe have a local shop read it for me. Are we talking about a pre cat or post cat O2 on the passengers side?
ah, running a scanguage. yea, your gonna need a proper scan tool with real time readings. You need to check your post cat. sensors. The internet is a great place and not only for ****.
How to Do a Voltage Test on a Oxygen Sensor | eHow.com
Rovin4Life,
Let me get this straight? I block the air intake with some type of can. Have an assistance crank the engine. It probably will not start because no air can enter the cycliners. Then listen for a hiss....And if I hear it, that is my vacum leak. Maybe from the lower valley gasket or where ever I hear it.
