16 in rims
16 in rims
So I came across some 16X8 rims online, he claims they are factory size for 2000-2002 Range Rovers. Will these fit on a 2003 Discovery 2?
Heres the post:
I have a set of four alloy rims that I purchased for a project and didn’t use. Only one has a center cap. They’re taking up space so no reasonable offer will be refused. These are factory wheels for the Range Rover, LR part #ALY72163U10. Land Rover calls them the “Lightning” model. The rim size is 16" x 8" and it will fit a 2000-2002 Range Rover. They may fit certain model years of the Discovery II but I haven’t tried so you would need to measure, first.
The rims are stamped with the following information: AWI Land Rover E - DOT, Tubeless ALY72163, 8J x 16 x 57.0 AH2. All are clean and in very nice, new like condition. There are a few minor scuffs from being stored that could probably be easily polished out. The tires are mix-n-match road tires that have about ¼” of tread left.
Heres the post:
Well according to this site they would fit okay.
http://www.rangerovers.net/outfittin.../p38tires.html
ANY wheels that fit a D2, will fit a P38 Range rover and vice versa
Over here they came with both 16" and 18" wheels. The picture jycsalas posted are the 18" hurricanes and are fitted to both D2's and P38's.
Yes the bolt pattern is the same, but its a mis conception that the drive train is idetical as there is a quite a LOT of differences.
RoverDude71
03-02-2009 11:03 AM
