1996 Disco: Hesitation at speed
Old 06-16-2010, 01:42 PM
M.Burroughs's Avatar
Default 1996 Disco: Hesitation at speed
Hey guys, I'm hoping for some help on resolving an issue with a disco I've been asked to help fix.
I come from the BMW world, so I know hardly anything about these vehicles, however, I am mechanically inclined.
The issue with the disco is this:
At ~55mph, the vehicle will hesitate. It will sputter a bit, drop to 50mph or so, and then "catch", and pick up speed again. This will cycle, almost like a "surge", a constant speed-up slow-down that happens roughly every 5 seconds.
This is not a constant issue. It seems intermittent. It's not something that happens every time I approach that speed. It seems to come and go as it pleases. It also only seems to happen in 5th gear (the vehicle is a 5-speed).
The same issue seems to happen sometimes around 70-75mph, although it is less common and less noticeable.
My first thought was perhaps a clogged fuel filter, however, it seems to "rhythmic" to be something of that nature.
I'm hoping my description is adequate for some diagnosing.
Any help is appreciated
-Mike
Old 06-16-2010, 02:46 PM
kenk's Avatar
First two thoughts off the top of my head are a fuel issue(pump) or vehicle speed sensor
Old 06-16-2010, 06:00 PM
My truck acts like this only not as bad if I get bad gas.
I am leaning towards a bad VSS.
Old 06-17-2010, 10:27 AM
I unplugged the VSS and haven't had the issue yet. The downside is the owner tells me the issue is very intermittent.
Old 06-17-2010, 11:00 AM
llcookej's Avatar
I had the same exact issue. It eventually worsened to do it around 35 as well. I unplugged the VSS and the problem never returned. I replaced the VSS and the issue returns when I plug it back in. It's most likely a bad wire somewhere in mine because it runs great when it's unplugged.
If it keeps running ok with the VSS unplugged, check the wires first.
BluePointDisco
07-11-2017 11:44 PM
BluePointDisco
11-09-2013 09:29 AM
soupdogg
09-25-2007 12:49 PM
tap121
05-06-2007 06:06 PM
tap121
04-01-2007 07:32 PM
Quick Reply: 1996 Disco: Hesitation at speed
