Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery II
Register Forgot Password?
Old 01-28-2012, 02:11 PM
Junior Member
Default 2 of the 3 amigo's
hey guys i have 2000 disco 2 and i had the 3 amigo's on so i did the abs mod and they were gone then i had to change the engine in it and now just the TC and HD lights are on not the abs light and the abs is still working on it just fine any thoughts would be great thanx
Old 01-29-2012, 09:30 AM
Send a message via Skype™ to Disco Mike
Have you tried the HD to see if it is working, if it isn't you need to get the system scanned for fault codes.
Let us know what you find.
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
To Download the RAVE Manual, follow this link http://www.landroverresource.com/
Rover Radio issues or IPOD Adapters http://home.valornet.com/splacket/index.htm
Need Parts?
paulgrant@mac.com, or 203-770-1699
willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
Old 01-29-2012, 10:22 AM
Junior Member
i had it scaned but the only code was in the slabs and it was signal fail from ECU so i changed it but the lights are still on and the TC and HD do not work
Old 01-30-2012, 08:21 PM
Junior Member
anyone have any ideals
Old 01-31-2012, 05:52 AM
Senior Member
I'd check wiring and the throttle position sensor. You have those two on because of a bad link or faulty data between the SLABS and Motronic ECM- either real or perceived by the software. Since you've swapped out the SLABS you know it lies somewhere else.
Start with the TPS and then let us know.
__________________
'03 D2
Super Pro Bushes; Was Koni HT, now HT RAID; Detroit Rear & TT Front; CDL then Quife torque biasing center diff; Style A Wheels; Scorpion ATRs; Goodridge Stainless Lines; EBC YellowStuff on DBA 4000XS; Big Valve Heads; 202 Cam; Stroked to 4.8L; Tuned Motronic; Added ACE & SLS; Euro Headlamps W/ Leveling & Powerfold Mirrors. Forced induction coming next.
Old 02-01-2012, 07:47 AM
Junior Member
ok changed the TPS and did not change anything scaned it again and still says signal lost from ECU thats what it said befor i changed the ecu would it posibly be a bad ground wire ???
Old 02-01-2012, 10:22 AM
Stop throwing parts at it. Send me your number and I'll call you and walk you thru what to check/do.
__________________
Mike
Need Parts?
Old 02-01-2012, 07:32 PM
Junior Member
pm sent thanx
Old 02-02-2012, 04:43 PM
Junior Member
ok changed the abs computer did nothing lol man i hate stupid lights
__________________
2000 d2 144 k
Tags
2000, amigos, discovery, ecm, fix, ii, land, landrover, rover, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
