Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery II
Register Forgot Password?
Old 01-31-2012, 04:08 PM
mydisco03's Avatar
Senior Member
Talking 2000 disco: front abs sensor low input?
Hi there guy's!!!! I'm working right now on a 2000 discovery, I found more than 16 abs codes.... One of then was the shutle valve. Wich i did replace with a new one and also did the by-pass. clear all those codes and I' m just getting the front right and left abs out-put low.... OK i did order the new sensors and install them today and still getting this sucker codes.. I did check every ground in the engine bay and inside the cabin by the brake pedals "top left"..... Also unplug every single plug to the abs computer and clean it with a small screw driver and plug it back in place.... If i clear the codes they come back in about a mile drive. HELP!!!!! 1.--Current Faults---->
Active Faults:
None
Logged Faults:
044:Front Right sensor output low
046:Front Left sensor output low
<-END Faults Thanks Guy's!!!!! I'm building bumpers and a bunch of more product's for only discos!!!! I will post pictures later!!!!
__________________
03 disco:Roof rack, 4 Hellas 4500, 100 watt's HID head light. Center Diff Lock and ARB Lockers front and rear with ARB compresor, Warn 12lbs winch, 35/12.5/R-16 PITBULL's ROCKERS. 5" lift Kit from rovertym, front radius arms, shock adapters from rovertym, mantec snorkel, ranchos 9000, Toms Wood front drive shaft And Toms Wood rear drive shaft... sway bars remove front and rear, Stainles steel brake lines, abs lines extended, rear watt linkage from rovertym, High lift and jerry can !
Old 02-02-2012, 10:10 AM
mydisco03's Avatar
Senior Member
Ok, I check the front sensors with a multimeeter and the were fine, also chech the wires on connector c0505 and it was fine too..... The problem was the front abs sensors "0 ring" If you dont set the abs sensor right in place the o ring will act like a spacer and will not send a stong signal to the computer.... that was the problem: got the 2 sensors out and back into place the right way.. That was the end of the story....... But Thanks any way my people!!!!
__________________
Old 02-02-2012, 03:28 PM
Send a message via Skype™ to Disco Mike
By the way, if you didn't do a full 2 quart DOT 4 brake flush, it will give you a little better pedal and less chance of eating up all the rubber seals in the system because of acidic, burned brake fluid.
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
To Download the RAVE Manual, follow this link http://www.landroverresource.com/
Rover Radio issues or IPOD Adapters http://home.valornet.com/splacket/index.htm
Need Parts?
paulgrant@mac.com, or 203-770-1699
willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
Tags
03, abs, back, discovery, land, left, low, output, put, range, rear, rover, sensor, signal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
