2000 Disco II - Can I drive it without front drive shaft?
Old 05-03-2010, 10:00 AM
TripleThreat's Avatar
Default 2000 Disco II - Can I drive it without front drive shaft?
In the process of having the front drive shaft rebuit on my 2000 Disco II. In addition, I'm installing an EBC Performance Brake upgrade since I do some towing with it.
Question is, can the Rover be driven while the front driveshaft is out without damaging anything?
Old 05-03-2010, 10:04 AM
greg409's Avatar
If your cdl works, lock it.
Then pull the front DS
You can drive all you want, (nicely, as the whole load is now on the rear diff)
I wouldn't spend any time over 60-70mph, tho'
luck,greg
JUKE179r (10-19-2016)
Old 05-03-2010, 10:23 AM
Get under your truck and reach above the transfer case. You can feel the nut that needs to be turned to engage the CDL. As said before don’t go crazy slamming the gas off of stop lights as this is going to put more pressure on your rear shaft, rotoflex and diff.
Old 05-10-2010, 10:05 AM
The CDL worked great. I was able to keep driving the Disco while the front driveshaft was being rebuilt by a local company ($183 - Universal Products - They also installed Grease Zerks in every u-joint).
Additionally, I got the EBC Performance Brake Upgrade installed - Slotted and dimpled rotors and EBC pads... Wow! What a difference!
Next step is to install a CDL engagement device in the cab... That may come in handy in wintery conditions or really muddy terrain...
Old 04-12-2011, 12:40 AM
jcserna's Avatar
3rd Gear
do you gays have eany pictures on were to lock de cdl. i am lost donot know where is the cdl lock. thanks..
Old 04-12-2011, 04:50 AM
put your truck model and year in you signature. what do you drive? the post marked spigot in this photo has a tab that can be turned with an open end wrench. it needs to be turned a 1/4 turn clockwise to engage the CDL.
photo courtesy of discovery2.co.uk
Old 04-12-2011, 06:53 AM
Bundu's Avatar
Banned
I didn't think gays would be driving discos?
Old 04-12-2011, 07:21 AM
vandev's Avatar
Default Lol
That has to be the funniest reply of the month!
Old 04-12-2011, 08:58 AM
coors's Avatar
HAAAY!
rj95lss
05-05-2017 06:56 PM
cminer
07-02-2015 09:48 AM
hriant88
11-09-2014 07:05 PM
zukilj20
07-31-2011 04:20 PM
grandkodiak
03-03-2011 10:02 PM
Quick Reply: 2000 Disco II - Can I drive it without front drive shaft?
