If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
Hi all, before you ask, NO, I don't have any codes. The only person with the tech to read the codes is 80 clicks away, so I haven't got anything more than what you read below at this stage.
Since a major beach excursion a few months ago, my Disco 2 - 2001 V8 has started running roughly. It's gotten worse recently and I thought it might have been related to the failed CPS that I just replaced. However, once the CPS was replaced, the car starts just fine now, but appears to misfire under load (ie, at intersections) or when cruising around town.. it's definitely noticeable to everyone on board.
I've looked at a bunch of other posts, but I really have no clue what it could be. I'm just looking for possible suggestions that I can take to my mechanic and have him try..
Thanks in advance!
Ando!
__________________
2001 Discovery 2 V8 Petrol 165000 KM / 102000 Miles
Location Gosford, Australia
So does it misfire and then the service engine light goes out? Or does the light not come on at all. You may just need some new plug wires and are having some arcing going on.
__________________
1997 Range Rover Beluga Black
1995 Discovery 1
1999 Discovery 2
A crank sensor will not cause a rough running engine, only a no start or hot start problem.
When was your engine last tuned along with new 8 mm silicone wires, have you checked/cleaned or replaced your air filter and what octane gas are you burning?
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
Need Parts? paulgrant@mac.com, or 203-770-1699 willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
Hi both!
Thanks for the fast response. To answer the first question, the "check engine" light does not illuminate.
For the second question, it was last serviced about a month ago where they air filter was replaced (I have visually confirmed this) but I am unsure if they replaced the spark plug cables or performed a tune up. As to the octane gas, I'm running 98 octane PULP.
What's your recommendation?
__________________
Does the check engine light not work? Does it come on and do the self test when you turn the key on but do not start the engine?
This sounds like a classic in the need of a good tune up.
The other thing could be corroded O2 sensors, I'm guessing your beach excursion was driving in salt water?
98 octane, God, I would kill for a tank of that, best I can get in Colorado is 91.
What color are your plug wires? If they are grey, they should be replaced along with plugs it they check out to be old also.
__________________
Mike
Hi Spike,
Yes indeed! We got seriously bogged in the dunes (a long way from the actual shore) and took us quite a few hours to get out. Are the O2 sensors the ones you can see just before catalytic converters on the exhaust? Oh and yes, the light comes on during the self test but does not illuminate once the car has been started.
And to Disco Mike.. If I could send you a tank full of 98 octane, I would . I will look into replacing the leads and the plugs.. that's a very good idea!
__________________
just a quick update. The price for 8 plugs is $200 and new leads is $115. Labour is not included, so we'll have to see what the final bill is and let you know. Should be done by this Thursday, so will post back then!
__________________
I cant believe the price of parts down there!!
Here I can get 8 spark plugs for $12.
Installing spark plugs is easy, doing the plug wires on a DII is not, but if you check the write up section it will tell you how.
