Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery II
Register Forgot Password?
Old 01-20-2012, 11:33 AM
MrFlea1's Avatar
Member
Default 2001 Disco SE7 Front cover
Well after putting this off for as long as I can I am now going to put the timing Gears/Chain back together. Have replaced the oil pump too. My question is what to do to remove the old gaskets that are on the aluminum cover. I know it says to use a 'plastic' scraper to minimize the chance of knicking the cover, but this gasket is really stuck on there. Do you think soaking it in degreaser would help ?
I have the "0" ring and a gasket the shape of the oil pick up tube....which is better to use or should I use BOTH?? Thanks for any input. I looked in the Rave manual but there is only mention of a "Plastic Scraper" so please don't answer me with Look in the Rave. Thanks
Old 01-20-2012, 12:01 PM
Senior Member
Solvent of some sort, but degreaser won't cut it. Main thing you are trying to do is not scrape the soft aluminum. So can't use 60 grit sandpaper, file, metal putty knife, etc. The refinishing department of most home improvement stores have some pretty sharp plastic putty knives.
__________________
Old 01-21-2012, 11:17 AM
DiscoDubs's Avatar
Junior Member
Try SeaFoam Deep Creep. It has worked wonders for getting some tough stuff unstuck for me, it works pretty fast too.
__________________
2004 HSE 86K Giverny Green/Tan
Mods: Nitto Terra Grapplers 255/60/18, On-board Air
Repairs: Head Gaskets @ 60K, Shuttle Valve Option B @ 66K, 60K Service @64K, New Front Driveshaft 71K
Old 01-21-2012, 11:29 AM
Senior Member
A couple of applications of gasket remover generally does the trick. Most of it will pull right off then after another application a microfiber towel and a little elbow grease will generally get the rest.
__________________
'03 D2
Super Pro Bushes; Was Koni HT, now HT RAID; Detroit Rear & TT Front; CDL then Quife torque biasing center diff; Style A Wheels; Scorpion ATRs; Goodridge Stainless Lines; EBC YellowStuff on DBA 4000XS; Big Valve Heads; 202 Cam; Stroked to 4.8L; Tuned Motronic; Added ACE & SLS; Euro Headlamps W/ Leveling & Powerfold Mirrors. Forced induction coming next.
Old 01-23-2012, 03:57 PM
MrFlea1's Avatar
Member
I actually loaded the parts in a plastic bag, put them in the MBenz trunk and went to the car wash and did a high pressure cleaning. most of the pieces cam off but a few stubborn ones needed some help. Looks good no scrapes so today is all done....tomorrow is another day and with luck I can finish the job tomorrow.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
