Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery II
Register Forgot Password?
Old 02-17-2012, 10:37 PM
Junior Member
Default 2002 Disco II
Hey guys, I'm looking at purchasing a 2002 Discovery Series II SE. 105k, GREAT condition. Battery was dead so we jumped it. M and S lights on, as well as Check Engine. Seemed to run great. Guy says it won't move, throwing a P0772 code (or P0722). Just curious if anyone else has seen this issue before. I've been searching like crazy and found some conflicting information, but nothing specific to the situation. I didn't try shifting it, but plan on going back to look it over thoroughly. Doing some searching I thought possibly it was from the battery, but it seems like something else. Maybe the XYZ switch? Output speed sensor?
It did also have a "wet" front axle from what looked like coolant, and coolant puddling on the exhaust/muffler. Presuming it's headgaskets. Any and all help is greatly appreciated! Looking to join the LR family. (Was looking for a Jeep, but I like to be...well different).
Old 02-18-2012, 03:40 AM
Member
Service engine soon light, S and M lights flash
Check this for the M S light issue. Wife left the sun roof open and the center console got soaked during a rain storm. Truck threw up the MS and went into limp mode. Took apart the center console dried everything with a hair dryer 6k later no issue and no codes.
Don't know with the coolant leak. I'd say first check all the hose connections make sure they're tight and go from there.
Good luck!
Old 02-18-2012, 07:44 AM
Senior Member
The the RAVE, the shop manual set you can download below, in the automatic gearbox section, P0722 is torque converter slipping. You most likely are looking at a vehicle that has not been maintained (like tranny fluid changes). So you could be buying a transmission rebuild, and head gaskets. If you like to wrench and this is a $500 Disco.... in other words, you might want to look at others that don't have a blown transmission, and engine damage of an unknown level. (at very best - tranny fluid and filter change, and throttle body heater gasket - if you are an optimist). www.statewidelist.com will search all of craigslist in your state and list by metro area, so you'll know what's out there for Rover.
__________________
Old 02-18-2012, 08:53 AM
Send a message via Skype™ to Disco Mike
So which code is it, makes a huge difference.
How much are they asking for this Disco?
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
To Download the RAVE Manual, follow this link http://www.landroverresource.com/
Rover Radio issues or IPOD Adapters http://home.valornet.com/splacket/index.htm
Need Parts?
paulgrant@mac.com, or 203-770-1699
willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
Old 02-18-2012, 08:02 PM
Junior Member
Thanks for the suggestions. It's the PO722 code. It sounds like it could be a myriad of problems/fixes. They're asking $2,990 but I can probably get it for under $2k. The truck is in otherwise GREAT shape. I'm super critical and this truck is one of the cleanest around. For the Year/Miles/Price, do you think it's worth it?
Old 02-21-2012, 05:30 PM
Junior Member
Also looked at a 99 with about 180k and a 2" lift. Allegedly same code, but works if you first put it in 1st, then switch up to D once moving....Decisions....
Old 02-21-2012, 06:26 PM
Senior Member
I would keep lookin....And find one that at least drives correct.
__________________
04 Disco II...Lifted....All serviced up(For Now)....
Old 02-21-2012, 07:55 PM
rimasco's Avatar
Senior Member
I got rid of my intemittent MS and 3 Amigos lights by cleaning the grounds and replaced the engine ground strap (snapped in half).. the other stuff I have no clue about..
Old 02-22-2012, 07:12 AM
drowssap's Avatar
Senior Member
it has a cooling issue, a brake issue, a transmission issue and a charging issue, and your still considering it, What does it need a meteor thru the roof issue to move on to another unit?
__________________
00 Disco 4.0 80k miles SLS, ACE, 7 passenger 255x65x18: Repairs since 02/11 new intake, valve cover, head, timing cover, waterpump & oil sump gaskets, new timing chain & gears, water pump, t-stat, hoses, belt, new front drive shaft, Akebono pads, D&S rotors, SS brake lines, clutch fan, HMS completed.
90 RRC County
67 mustang GTA
73 Jeepster Commandos
69 Honda SOHC
71 HD FX
72 BSA Lightning
73 Honda SOHC
78 Honda SS
87 HD FLTP
2004 HD SE 103
He who dies with the most toys, WINS
Old 02-22-2012, 08:30 AM
Senior Member
Quote:
.....I just choked on my cereal....A meteor....Ahhhahhh
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
