Howling Noise from engine
Old 11-20-2012, 09:42 PM
mx468's Avatar
Default Howling Noise from engine
Ok I went to start up my truck today and it started to howl from my engine. When I rev it, the howling goes up. I looked and listened and it seems to be coming from the front top of belt. Any ideas?? Thanks.
Old 11-20-2012, 09:47 PM
Michael M. Koch's Avatar
Tension pulley or A/C compressor clutch could be worn out.
Old 11-21-2012, 01:31 AM
Bkreutz's Avatar
Loosen the tensioner (or take the belt off) and spin each of the pulleys (including the A/C) and see which one is noisy or stiff and replace it, if you don't it will eventually lock up and burn the belt off. (then the water pump stops turning and the little red light comes on...........)
Old 11-21-2012, 08:29 AM
Also, before taking off belt you may be able to "listen" to various items with a long stick or screw driver pressed aginst your ear. Bad bearings make lots of noise, the stick helps focus on one spot and overcome nearby engine noise. Helps keep your dreadlocks out of the belt pathway (safety first).
gribur
02-14-2015 09:37 AM
geek_IM
10-04-2010 11:02 AM
Eulogio
01-21-2008 04:17 PM
baddiscoII
08-07-2007 01:07 PM
adrianwood
Freelander
06-13-2005 08:53 PM
Quick Reply: Howling Noise from engine
