2003 Disco II Changing Spark Plugs - Land Rover Forums - Land Rover Enthusiast Forum
Old 08-06-2008, 10:00 AM
Junior Member
Default 2003 Disco II Changing Spark Plugs
Would someone please send the proper instruction on how to remove the intake on my 03 Disco 4.6ltr V-8. I have the parts comming (magnicor wires, bosch 4 plugs, new intake gasket) but it looks a bit complicated to remove. Any help would be appreciated.
Old 08-06-2008, 10:06 AM
brooksa's Avatar
Senior Member
Default RE: 2003 Disco II Changing Spark Plugs
You can change the wires without removing IM,
Old 08-06-2008, 10:47 AM
Try this link. Unless your valley pan or v/c gaskets are leaking beyound control, don't remove the intake.
http://www.landroverforums.com/m_41479/tm.htm
Thread Thread Starter Forum Replies Last Post
Cold weather, batteries, glow plugs and spark plugs. OffroadFrance Off Topic 0 01-14-2015 05:56 PM
Help changing spark plugs... spirex LR3 6 01-08-2013 11:58 AM
Problems Starting after changing Spark Plugs nhigdon11 Discovery II 9 12-19-2012 09:38 PM
need help changing spark plugs and correct gapping Classklown90 Discovery II 29 05-02-2010 10:34 PM
Changing Spark Plugs on Freelander MidasHands Freelander 2 06-05-2008 06:50 PM
Tags
03land, 2003, change, changing, discovery, ii, im, land, landrover, pic, plugs, remove, rover, spark, wires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
