2003 Land Rover Discovery G4 Winch Mount
Old 12-07-2013, 04:49 PM
roverwoody's Avatar
I'm really looking for this winch mount like the G4 Discovery so that I can still keep the look of the original bumper.
Old 12-07-2013, 10:58 PM
acg's Avatar
acg
acg is offline
Try searching for the Terra Firma or Bearmach discrete winch mounts.
Here is an example of the installation:
www.discovery2.co.uk / T-Max Winch
Old 12-08-2013, 01:28 PM
acg's Avatar
acg
acg is offline
For D1:
http://www.lucky8llc.com/Products.aspx?ProductID=7731
For D2:
http://www.lucky8llc.com/Products.aspx?ProductID=7732
Alternatives:
http://www.autopartswarehouse.com/sk...492302289.html
P/S.
I also recommend changing out the front springs to a heavy-duty version as the substantial weight of the winch assembly will drop the front end.
Old 12-08-2013, 07:06 PM
roverwoody's Avatar
Thanks for the links.
Old 12-08-2013, 07:08 PM
roverwoody's Avatar
I was thinking more on the lines of this.
Old 12-08-2013, 08:32 PM
TRIARII's Avatar
Attachment 18973
Attachment 18974
I love the Trek and G4 editions but the exposed winch setup concerns me. Firstly is fully exposed to the elements, so I imagine it wont take long for the metals to rust over, especially if you live in New England or anyplace with cold weather where salt is put on the roads. Next it looks like an open invitation to thieves looking to get a bargain on a new winch! Next what about approach angle? If your in a frontal position there the bumper is close enough to an obsticle like say a boulder, wouldnt that winch location be a mad idea?
I think a better solution is a discrete winch setup thats locked in securly, and not as exposed to the elements and does not overhang on the front bumper. Just my opinion though.
Old 12-09-2013, 04:13 PM
roverwoody's Avatar
Thanks for the comments of concern. I like the exposed look. My Disco isn't my daily driver. I will take your comments in consideration.
Old 12-09-2013, 04:17 PM
jafir's Avatar
Being able to see the winch drum is good anyway.
Old 12-10-2013, 09:45 AM
roverwoody's Avatar
I agree. I'm will as swap the cable with a synthetic line.
Old 12-10-2013, 11:40 AM
primussucks's Avatar
If you never plan on using your winch, discrete is fine... if you ever plan on using it, this is a bad idea.
You cannot see if your wire/rope is spooling properly, you are just guessing until it is too late. You should always be able to see the wire/rope and spool.
Quick Reply: 2003 Land Rover Discovery G4 Winch Mount
