#5 Cylinder Misfire Detected
I was driving along when the engine shook things up a little it was missing and then things went smooth again. The check engine light came on and the code was P0305: Cylinder #5 misfire detected. I changed the spark plugs even though the looked fine. Got some Bosch Fusion plugs for it. The wires looked fine. But then it did it again. P3035 and P0300: Random Misfire Detected. It is a very rare occurance and it seems to do it after a cold start. Any thing I should check or any recommendations? Thanks in advance.
RE: #5 Cylinder Misfire Detected
What year? They are still $30 cheaper than Tony @ www.Apexperformance.net.I got them from here and they were pretty fast getting here. They were the right wires too, 8MM PN# 80142.
ORIGINAL: xb70valkarye
I am glad I read this before I went out and bought them. Do you have a web address for me? Thanks.
I have the old P305 code too. I got my Magna 8MM's ordered from Apex last week. Hope to have them soon. Nice can of BG44 coming too (thanks OKDiscoGuy) I'll let you know how it turned out.
Mike - OKDiscoguy - How easy it it to DYI on changing out the wires. I have no room at all behind there. Literally its like 4 inches max to fit my hand. I don't want to have to start taking stuff off unless I have to.
Do you have secondary air, an emission control device that runs pipes behind the engine?? If so it is hell, other wise I would suggest you crawl up on top of the engine and pull one wire at a time, it is alot better them paying just under $200 in labor.
Don't use the 44K until you are ready to take a couple hour drive, it works much better that way.
