Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery II
Register Forgot Password?
Old 01-15-2012, 02:19 PM
Junior Member
Default 99 Series II, brake light switch, struck in park
1999 Discovery Series II. Problem seemed to start with blown fuse (#11) LH side & tail light, number plate light. Replaced fuse. Based upon on previous posts, probably unrelated.
The next day was stuck "in park" in driveway...it started later and worked fine....then got stranded - stuck "in park" again. Depressed safety pin under shifter cover....made it home.
Replaced with OEM brake light switch. Still no brake lights and safety pin will not release. Drives fine with no brake lights although still need to manually release switch. I should also mention the back-up lights have not worked for some time (not been an issue aside from not working while in reverse).
Is there a solenoid that could be bad....causing problem with the lights and safety release?
Old 01-15-2012, 07:13 PM
Philip Lawrence
Send a message via Skype™ to Spike555
Check for water and or corrosion in the left rear tail lamp assembly.
It was a common problem for late model DII's to develop leaks in that tail lamp, corrode the wiring and cause all kinds of havoc.
Some have had to to splice in a new wire harness.
__________________
www.marshill.org
Walk by faith not sight.
The "Storm Trooper", 1997 Discovery with 212,000 miles.
www.20liters.org
Old 03-11-2012, 06:42 PM
Junior Member
Not a daily driver so just got back focused on it. Still having issues.
All other lights work except the brake lights.
Any other ideas?
Old 03-11-2012, 09:43 PM
Senior Member
Fuse 21, inside truck fuse box. Power from that, thru a relay on back of fuse panel (driven by IDM and BCU) to the solenoid. RAVE electrical schematic attached.
__________________
Old 03-20-2012, 08:27 AM
Junior Member
Default Brake Switch Issue Resolved
After changing the brake switch, make sure to re-install in its harness before testing. Painfully - I did not, and mistakenly thought the issue was not the switch. Apparently, there must be a sequence the ECU runs before the switch will work (i.e., plunger in when key turned and then plunger out to release solenoid and illuminate the brakes).
Tags
1999, brake, discovery, ii, land, light, lights, park, pedal, picture, release, rover, series, shifter, stuck, switch, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
